Go Back   Viper Club of America Discussion Forums > Archives > Archive Management
Archive Management This is a forum to discuss the addition of "OLD" messages from the off site archives. Do not discuss anything that is posted in the forums above.
Old 11-23-2000, 09:26 PM   #1
Supercharged Vipermad
Seasoned Enthusiast
Default Re: Tire size Limit?
Yeah, shouldn't be any problem. I've raced before with 335/30/18 fronts (stock suspension GTS) and the tire never rubbed. I'm sure the rear would accept at least a 345 rear.
Supercharged Vipermad is offline   Reply With Quote
Old 11-24-2000, 02:10 AM   #2
Brad Manhattan Beach
Who makes a 345 for the rears? Do they have them in 17 inches?
Brad Manhattan Beach is offline   Reply With Quote
Old 11-24-2000, 10:01 AM   #3
LTHL VPR
The only concern you may have with a 345/35/18 Michelin Pilot Sport is that the tire is taller and the car will ride about 1/2" higher in the rear. Michelin has a 345/30/19 that is slightly shorter and will make the car ride about .4" higher in the rear.
Interestingly, I saw the review of the new Saleen S7 in Motor Trend. In the specs it listed the rear wheel as a 19x13 with a 355/25/19 Pirelli Rosso Assym.
This would look GREAT on the VIPER, and would not raise the car; in fact it may lower it negligibly.
LTHL VPR is offline   Reply With Quote
Old 11-27-2000, 05:50 PM   #4
Jerry Scott[CO]
Jerry Scott[CO]'s Avatar
The 285s work just fine on the front. The only concern that you should have is when the hood is open in the front, if you drive the car and steer the wheels, the tires will hit the lower corner of the wheel cut out in the hood, and possibly break it off.
Jerry Scott[CO] is offline   Reply With Quote
Tire size ? acrdakota RT/10 and GTS Discussions 1 06-27-2005 06:18 PM
Different Tire Size NOTV8 RT/10 and GTS Discussions 1 06-18-2005 10:06 PM
Tire Size Snake Bitten RT/10 and GTS Discussions 1 05-09-2002 02:09 PM
Tire size mchafin RT/10 and GTS Discussions 4 04-13-2002 02:35 PM
Tire size for my 96 RT/10 Supercharged Vipermad Archive Management 1 11-06-2000 02:37 PM
