Go Back   Viper Club of America Discussion Forums > Archives > Archive Management
Archive Management This is a forum to discuss the addition of "OLD" messages from the off site archives. Do not discuss anything that is posted in the forums above.
Old 11-09-2000, 07:54 AM   #1
Marc Lublin
Default Aluminum Rims best way to polish?
My 2000 has polished aluminum rims as do all I think. While they are still perfect I'm sure eventually I will touch a curb. We all know that on these cars, the rims hit first. I want to be, prepared so can anyone tell me their remedies for removing the nicks and polishing. I would think either drill or dremel with fine stone to remove and some type of polishing wheel to shine. If so, where does anyone recommend picking up the necessary stuff.
Marc Lublin is offline   Reply With Quote
Old 11-09-2000, 09:10 AM   #2
Matt M, PA
Matt M, PA's Avatar
Default Re: Aluminum Rims best way to polish?
The wheels on your car are indeed polished aluminum...then clear coated. Short of using a good car polish (Zaino, there is really no other care you can do. If you use a metal polish you will damage the clear coat.
Old 11-09-2000, 03:36 PM   #3
Marc Lublin
I don't think the wheels are clear coated. I'm not talking about anything that Zaino or any other polish/wax can help on. I'm talking about smoothing out scrapes on the rim. Anyone else have a 2nd opinion?
Old 11-09-2000, 05:54 PM   #4
Matt M, PA
Matt M, PA's Avatar
Here we go again. Every Viper since 1996 has had clear coated wheels. (Except the painted ones on '96 RTs) I have friends that operate a mag wheel shop, and this is what they do. To get rid of a nick on the face of the wheel, you will want to use the least abrasive manner you can. Maybe some 2000 grit wet-dry sandpaper, but bear in mind that you can't go far without going through the clear coat. If you damage the edge of the rim, you can file the damage smooth with a very fine file. Either way, there is really no way to "fill" the damage that I know of. If you need to use power tools, you are better of leaving to an expert.
Old 11-11-2000, 09:04 AM   #5
Silver98
Silver98's Avatar
I must confess that I did scrape one front rim soon after I took delivery of my Silver Bullet. I used a small Dremel tool to smooth it back and it can hardly be seen now. The clear coat must be very thin because you can not see it around the polished area.
Silver98 is offline   Reply With Quote
What Are Best Products to Clean/Polish 10 Spoke Rims?? Tommy K SRT10 and SRT10 Coupe Discussions 3 04-02-2007 06:04 AM
POLISH AND WAX 93viper RT/10 and GTS Discussions 2 10-24-2005 04:28 PM
Polish aluminum....where to get the polish ab RT/10 and GTS Discussions 5 07-24-2004 03:19 PM
Rims--can you polish your own? ACR Joe Archive Management 1 04-12-2001 03:04 PM
Intake and Mothers Aluminum Polish Gerald Archive Management 1 01-24-2001 03:31 PM
