Go Back   Viper Club of America Discussion Forums > Archives > Archive Management
Archive Management This is a forum to discuss the addition of "OLD" messages from the off site archives. Do not discuss anything that is posted in the forums above.
Old 06-04-2001, 09:09 PM   #1
Lee Dove
Default What\'s the trick?
Gen 1, removing the thermostat housing? Have all hose's off housing unbolted from block. Can't get enough room to get it between intake and bottom windshield edge....
Lee Dove is offline   Reply With Quote
Old 06-04-2001, 09:22 PM   #2
Doug Supercharged Vipers
S. Fla. VCA Member
Default Re: What\'s the trick?
Lee,
At this point;
A) You can remove the intake or
B) Separate or open the thermostat hsg and it will fit past the intake in two pieces.
Good Luck,
Doug
Doug Supercharged Vipers is offline   Reply With Quote
Old 06-04-2001, 09:30 PM   #3
Rich Carlson
Hey Lee, I am just checking, did you remove the cowl trim panel ????
Rich Carlson is offline   Reply With Quote
Old 06-04-2001, 09:35 PM   #4
Lee Dove
Thanks Doug, I knew you were going to say that.... The shop manual is not clear......
Rich, yes the cowl is off.
trick plumbing 99t1 RT/10 and GTS Discussions 3 05-11-2006 09:51 PM
Stock or Trick?? toppy RT/10 and GTS Discussions 12 05-24-2005 04:42 PM
Any trick airboxes! TOOOFST RT/10 and GTS Discussions 7 01-11-2005 06:54 PM
Is there a trick for getting into reverse? Buzzzz RT/10 and GTS Discussions 17 04-02-2002 10:26 AM
