Go Back   Viper Club of America Discussion Forums > Racing and Performance Modifications > Viper Racing/Dyno Results/Time Slips > Dyno Results
Dyno Results Post your dyno results and graphs here!
Sponsored by: DragTimes.com
Old 04-28-2008, 01:18 PM   #1
MKB96Viper
MKB96Viper's Avatar
Default 08 Viper with headers and 150 shot of nitrous!!
Well gang, these new engines like the nitrous. This car has 1800 miles on it with the following mods:
3.33 Unitrax gears with Quaife rear.
heavy duty half shafts
K&N Filter
Belanger Headers, H/F cats, and exhaust
Macedo Motorsports custom Nitrous Upgrade with 150 shot. (one step colder plugs)
The A/F ratio lands right around 11 - 11.5 just like it should be.
Power jumps from 570rwhp to 733!!
Torque jumps from 542 to 799!!!
2008 SRT10 Vert - 10.86 @ 128.29mph , All motor
MKB96Viper is offline   Reply With Quote
Old 04-28-2008, 01:41 PM   #2
mjorgensen
Default Re: 08 Viper with headers and 150 shot of nitrous!!
Are they going to be able to smooth out the big hump? Very impressive numbers though no doubt!
Were there check engine lights etc...?
Old 04-28-2008, 02:28 PM   #3
Bobpantax
FL VCA Member
Bobpantax's Avatar
K&N Filter
1. Is the nitrous staged or does the 150 come in all at once?
2. Is it a wet or dry kit?
3. Does the kit include a bottle opener and closer?
4. A bottle warmer?
5. If the nitrous comes in all at once, in what gear and at what speed are you activating it and how is traction?
6. Are you doing this with the stock Pistons?
Things go better with boost.
Bobpantax is offline   Reply With Quote
Old 04-28-2008, 03:11 PM   #4
MKB96Viper
MKB96Viper's Avatar
Here are some answers:
No check engine lights.
No software to tune out that drop yet.
1. Is the nitrous staged or does the 150 come in all at once? All at once.
2. Is it a wet or dry kit? Wet
3. Does the kit include a bottle opener and closer? Both
4. A bottle warmer? yes
5. If the nitrous comes in all at once, in what gear and at what speed are you activating it and how is traction? I will use it from a stop in first gear at the track only with the slicks.
6. Are you doing this with the stock Pistons? yes
I'll keep you updated when I can get her to the track.
Keith
Old 04-28-2008, 04:07 PM   #5
johnk
It will be interesting to see if the stock pistons hold that power.
Good luck.....
johnk is offline   Reply With Quote
Old 04-29-2008, 09:04 PM   #6
Camfab
Camfab's Avatar
That thing is going to clean up at the track! I'm not going to say what I think it's gonna run, I'll let you have those honors. Wow.
Old 05-11-2008, 05:51 AM   #7
CO-NOS-Viper
Colorado VCA Member
Proudly Serving Overseas
CO-NOS-Viper's Avatar
Wow I see that thing running low 10's or high 9's with slicks. Thats just sick that your Stock rwhp is about the same as my nitrous rwhp. Its amazing how much the torque jumps on these engines running nitrous. That thing is going to be a beast on the track. I just hope everything holds up. Are those cast or forged pistons that come in the 2008's. Please tell me they went forged pistons instead of keeping the cast ones.
2004 SRT-10 Black 447rwhp/466rwtq NA(595rwhp/740rwtq) 200 Shot
LONG LIVE TATORS DODGE
CO-NOS-Viper is offline   Reply With Quote
Old 06-29-2008, 09:22 AM   #8
boosted349
nope they r cast
boosted349 is offline   Reply With Quote
Old 06-29-2008, 09:55 AM   #9
Warfang
When an all you can eat buffet just quite ain't enough....
Good lord! I know this goes without saying, but be safe in that thing. Sounds like a total monster!
97 GTS red/white
Warfang is offline   Reply With Quote
Old 06-29-2008, 02:22 PM   #10
Hamrhead
WV/PA VCA Member
Hamrhead's Avatar
Great Numbers!
Is the time in your sig WITH all of the other mods except Nitrous?
Mike
'06 Black Coupe
Hamrhead is offline   Reply With Quote
Old 06-30-2008, 06:38 PM   #11
MKB96Viper
MKB96Viper's Avatar
Thanks guys,
The number in my signature IS with all the mods except the nitrous. I have not been able to run a full pass with the nitrous yet. There seems to be a torque management restriction in the stock ECU. When the ECU sees a spike in the torque numbers when you change gears its closing the throttle bodies, thus slowing the car. It will run fine as long as its a one gear run. Pick a gear, any gear, it pulls like a rocket and as soon as you shift up to the next gear the ECU slows the car. Drives me crazy! I am wide open for suggestions.
Anyone else experiencing similar problems??
Keith
Old 06-30-2008, 06:59 PM   #12
Bobpantax
FL VCA Member
Bobpantax's Avatar
Have you communicated with Dan Cragin about the possibility of him reprogramming your controller? If not you need to contact him. He would know if it can be done.
Old 06-30-2008, 08:52 PM   #13
mjorgensen
With all of the "new" engine controllers using the electric TB control is very hard to achieve. This is part of the reason the manufacturers are going this route I suspect. The Viper is not the only car that is seeing this tuning problem. There are others making power only to be robbed as you are by the PCM and it's FULL control over the TB.
Sorry
Old 07-01-2008, 06:43 AM   #14
MKB96Viper
MKB96Viper's Avatar
Anyone know of any tuners that can remove or increase the torque managment? We are ALL going to need this when you make any good power gains.
Thanks,
Keith
Old 07-01-2008, 07:34 AM   #15
2001 GTS
Sounds like that will be the only way to beat an 08!
But should be able to tune it out or unplug something
ok..nitrous creampuffs...what size shot ya using? prevnine11ownr RT/10 and GTS Discussions 1 06-11-2004 04:53 PM
RT/10 with 100 nitrous shot AlvaSpeed RT/10 and GTS Discussions 0 06-03-2004 04:55 PM
Dry shot of nitrous ( Who has been there??) BlackACR RT/10 and GTS Discussions 15 06-02-2003 06:20 PM
Dry Shot of Nitrous?? BlackACR RT/10 and GTS Discussions 3 02-16-2003 08:37 PM
Nitrous Express 100-300hp shot, $750?... Sean Roe Archive Management 21 04-25-2001 07:02 AM
