Old 10-07-2007, 07:41 PM   #1
Purdue_Boiler_Viper
Default How to monitor both banks with Innovate?
Trying to figure out how to monitor both banks with the LC-1. Looks like you just buy two of the LC-1s, and run serial out of #1 to serial in of #2. Serial out of #2 goes to the PC. Are you guys using the Innovate software (LogWorks) to monitor the LC-1 or something else?
Old 10-07-2007, 07:57 PM   #2
ViperTony
ViperTony's Avatar
Default Re: How to monitor both banks with Innovate?
You can also use the Vec3 to monitor output from both widebands using the analog inputs available on the Vec3. This way you can capture AFR in addition to outher inputs such as RPM, intake air temperature, map pressure, etc. when logging through the Vec3. There's a writeup on how to use the Vec3 to capture AFR from the LC-1 in the illustrated upgrades section.
WE SAVED TATOR'S DODGE
Old 10-09-2007, 06:01 AM   #3
DC Performance
SO CA VCA Member Site Supporter
DC Performance's Avatar
For those interested we can custom tune your controller to your dyno sheets and modifications. Please fee free to call.
310-841-6996
Old 10-09-2007, 09:41 AM   #4
ViperTony
ViperTony's Avatar
Trolling are we? I think you caught BigBrakeDave-itis!
Old 10-09-2007, 10:12 AM   #5
dun4791
Illinois VCA Member
dun4791's Avatar
No, if you want to monitor both banks seperately and you already have 1 LC-1, then just add the LM-1. The LM-1 is capable of monitoring both banks using your existing LC-1 for one of the banks. And if you dont already have the VEC3 Tony is referring to, you can monitor your IAT,RPMs,map pressure, etc. through the LM-1 as well. And yes use logworks.
dun4791 is offline   Reply With Quote
Old 10-09-2007, 10:53 AM   #6
Purdue_Boiler_Viper
Sorry, I was not clear. I want to monitor both banks simultaneously. I do have the Vec3. So, It appears that I can separately wire them to the Vec3, using the analog inputs of the Vec3. Then use the Roe SW.
Old 10-09-2007, 11:24 AM   #7
dun4791
Illinois VCA Member
dun4791's Avatar
Sorry, I wasnt clear either. You can monitor both banks seperately and simultaneously using the LM-1, and apparantly (no experience with the VEC) with the VEC3 as well.
Old 10-09-2007, 01:03 PM   #8
KenH
KenH's Avatar
The good thing about running it in through the VEC3 is that you can also log all the other parameters that the VEC3 monitors or modifies like injector pulsewidth, timing and the VEC internal MAP sensor.
Roe SC 6.5lb, water/methanol
3:55 gears, PBJ Intake
CCW 505A w/ PS2's 19" x 20"
Old 10-13-2007, 07:41 AM   #9
Jack B
Jack B's Avatar
I have run both the vec and Logworks, there is no comparison. I love my VEC, but, the logging capability of the vec does not compare. If you use any of Innovates interfaces you can log all of the 0-5 pcm's functions.
I am also adding a second a/f sensor, you will need either an LM1 or DL32. If you go with the dl32, you have the ability to log up to 32 channels, plus, it has built-in functions such as an accelerometer, egt input and others. The DL32 also records to a SD card, therefore, giving unlimited logging time and transportability of data.
Jack B
10.2 @140 (1.7 sec 60')
1.45 (best 60')
Old 06-01-2008, 05:24 PM   #10
SYNFULL
SYNFULL's Avatar
I have read this post a few times and still am not clear. I would like to log both banks with my vec 2, and i would like 2 a/f gauges. Can I do this with 2 LC-1's and 2 air fuel gauges?
Is there anything else I would need?
I would like to install the sensors in the rear 02 sensor location. I have 02 simms so I don't need the rears. I have no cats and everything is welded so there should be no leaks.
Thanks!
Gary
99 ACR Silver/Steel Grey Stripes- Roe SC 8lb, Roe Heads, W/M, Bellanger, Random Tech, Iforged Wheels.
SYNFULL is offline   Reply With Quote
US Banks - Which One? Torquemonster Sneaky Pete's Place 4 11-22-2004 12:05 PM
most accurate way to monitor AF V10 MOJO RT/10 and GTS Discussions 7 08-15-2004 08:43 PM
XP Laptop w/2nd Monitor! Tom and Vipers Sneaky Pete's Place 2 01-22-2003 10:34 AM
Stupid a$$ banks Chuck 98 RT/10 Sneaky Pete's Place 17 09-26-2002 02:48 PM
