Are you guys permanently mounting the LC-1 switch and LED for periodic calibration? What creative mounting ideas have you come up with if so?
Are you talking about mounting that little red reset button? If so, I followed DY's instructions and mounted the switch behind my PCM cover plate. I installed the LED indicator per DY's illustration into the PCM cover by drilling a small hole through it to fit the LED. This allows me to see the LED from the 'gill' under the hood, driver's side. For a calibration (just did one) I just reached into the PCM cover and pushed the button. Its out of the way yet easy to get to.
Yeah. I'm looking at the Innovate warning:
WHEN INSTALLED IN THE EXHAUST, THE OXYGEN SENSOR MUST BE CONNECTED AND OPERATING WITH THE LC-1 WHENEVER THE CAR IS RUNNING. AN UN-POWERED OXYGEN SENSOR WILL BE DAMAGED WHEN EXPOSED TO EXHAUST GAS. So, I guess you guys are peeking through the grill to see if the LED shows normal operation. I was thinking of something in the cockpit. Substitute a NASA looking switch for the momentary pushbutton, and you have something that could look like a rocket launcher. ![]() |
#4 | |
I'm going to monitor both banks. I was thinking of a couple of these, with suitable annunciators.
here's a couple pics of my setup inside the car
I think it is stealthy yet easy to use in the car and looks clean this is on the panel under the steering column the headlight switch is to the left of the button/LEDs and the fusebox is at the bottom of the panel there is only 1 momentary button because I wired the black wires together after the LEDs I figure there will never be a reason not to calibrate the sensors at the same time the LEDs are separate to monitor the codes from each sensor I see this as superior to mounting the LEDs in the engine bay because I will know if the sensor is sending a code while I'm driving
97GTS B&W: Roe S/C 5#, VEC3, Borla headers, catless exhaust, smooth tubes, T&D rockers, 3.55 gears, RPS flywheel & 6-puck clutch, short-shift kit, untuned coming soon: N2O
sorry, forgot to attach the pics
![]() I can get a pic installed in the car if anyone cares |
#8 | |
I like it. May I ask where you tapped 12V for the sensors?
#11 | |
| INNOVATE LC-1 to Vec set-up question | DAMN YANKEE | RT/10 and GTS Discussions | 13 | 04-27-2007 07:51 AM |
| Innovate Wide Band | BlueGTS | RT/10 and GTS Discussions | 2 | 08-13-2006 02:37 PM |
| Innovate LM-1 | mntngts99 | RT/10 and GTS Discussions | 2 | 07-26-2006 06:38 PM |
| Show me your nitrous WOT switch mounting | GTSnake | RT/10 and GTS Discussions | 6 | 07-07-2006 08:50 PM |
| Tune your car! innovate | v8huntr | RT/10 and GTS Discussions | 5 | 01-15-2004 11:30 AM |
