Old 01-28-2008, 12:32 PM   #1
Purdue_Boiler_Viper
Default Innovate LED / switch mounting
Are you guys permanently mounting the LC-1 switch and LED for periodic calibration? What creative mounting ideas have you come up with if so?
Old 01-28-2008, 12:44 PM   #2
ViperTony
ViperTony's Avatar
Default Re: Innovate LED / switch mounting
Are you talking about mounting that little red reset button? If so, I followed DY's instructions and mounted the switch behind my PCM cover plate. I installed the LED indicator per DY's illustration into the PCM cover by drilling a small hole through it to fit the LED. This allows me to see the LED from the 'gill' under the hood, driver's side. For a calibration (just did one) I just reached into the PCM cover and pushed the button. Its out of the way yet easy to get to.
WE SAVED TATOR'S DODGE
Old 01-28-2008, 02:41 PM   #3
Purdue_Boiler_Viper
Yeah. I'm looking at the Innovate warning:
WHEN INSTALLED IN THE EXHAUST, THE OXYGEN SENSOR MUST BE CONNECTED AND OPERATING WITH THE LC-1 WHENEVER THE CAR IS RUNNING. AN UN-POWERED OXYGEN SENSOR WILL BE DAMAGED WHEN EXPOSED TO EXHAUST GAS.
So, I guess you guys are peeking through the grill to see if the LED shows normal operation. I was thinking of something in the cockpit. Substitute a NASA looking switch for the momentary pushbutton, and you have something that could look like a rocket launcher.
Old 01-28-2008, 03:08 PM   #4
ViperTony
ViperTony's Avatar
Yes, peeking when the car is running. I like your idea about the NASA switch!
Old 01-28-2008, 07:09 PM   #5
Purdue_Boiler_Viper
I'm going to monitor both banks. I was thinking of a couple of these, with suitable annunciators.
Old 04-02-2008, 09:43 AM   #6
BOTTLEFED
ID VCA Member
BOTTLEFED's Avatar
here's a couple pics of my setup inside the car
I think it is stealthy yet easy to use in the car and looks clean
this is on the panel under the steering column
the headlight switch is to the left of the button/LEDs and the fusebox is at the bottom of the panel
there is only 1 momentary button because I wired the black wires together after the LEDs
I figure there will never be a reason not to calibrate the sensors at the same time
the LEDs are separate to monitor the codes from each sensor
I see this as superior to mounting the LEDs in the engine bay because I will know if the sensor is sending a code while I'm driving
97GTS B&W: Roe S/C 5#, VEC3, Borla headers, catless exhaust, smooth tubes, T&D rockers, 3.55 gears, RPS flywheel & 6-puck clutch, short-shift kit, untuned
coming soon: N2O
Old 04-02-2008, 09:46 AM   #7
BOTTLEFED
ID VCA Member
BOTTLEFED's Avatar
sorry, forgot to attach the pics
I can get a pic installed in the car if anyone cares
Old 04-02-2008, 09:46 AM   #8
Purdue_Boiler_Viper
Pics? I'd love to see your setup.
Old 04-02-2008, 09:51 AM   #9
Purdue_Boiler_Viper
I like it. May I ask where you tapped 12V for the sensors?
Old 04-02-2008, 10:15 AM   #10
puma
puma is offline   Reply With Quote
Old 04-02-2008, 10:22 AM   #11
Fast Too
Fast Too's Avatar
If you purchase one of their serial A/F gauges to go with the LC-1 you get the cal button and LED integral to the gauge. That would probably be the ideal solution for a cockpit mount. The alternative to that (with an analog gauge) is to program the LC-1 analog output to that gauge to show a total rich or lean condition (your preference) when the LC-1 detects an error.
'06 SRT-10 Coupe
INNOVATE LC-1 to Vec set-up question DAMN YANKEE RT/10 and GTS Discussions 13 04-27-2007 07:51 AM
Innovate Wide Band BlueGTS RT/10 and GTS Discussions 2 08-13-2006 02:37 PM
Innovate LM-1 mntngts99 RT/10 and GTS Discussions 2 07-26-2006 06:38 PM
Show me your nitrous WOT switch mounting GTSnake RT/10 and GTS Discussions 6 07-07-2006 08:50 PM
Tune your car! innovate v8huntr RT/10 and GTS Discussions 5 01-15-2004 11:30 AM
