Just a quick update in some revised street gas timing table for my 02 GTS. So far, no problems on pump gas, although I added a little more fuel of 2ms pulses. Low/midrange SOTP is certainly there, even on 100 degree days. I also moved the IAT out of the 'open' box, and into the base of the filter so it measures only the air received by the engine (to lessen the retarding of timing based on IAT readings from a 'heat soaked' engine compartment. Take a look at the graph and have fun.
Rob ![]() 2002 GTS - Sewer Pipe Exhaust with VECII Enhancements and Texas Nitrous Technology 'Insurance Policy' !!! Hope to see you on the NORTH end of the tollway ![]() |
That's good to see. Nicely graphed. Im not running too much differently with W/M and 5lbs of boost. For whatever reason, the stock timing is very conservative, especially 4-5K.
2001 Race Yellow/Custom White GTS; 6.5 lb ROE, Custom W/M, Bellager, Hi Flow-Cats/Corsa, Eibach
What values are you putting in the vec timing table?
Steve |
Thanks EllowViper.
To 2001GTS and All.....Here is the detail on my modified ‘advanced’ timing/fueling. Also refer to the updated, attached chart. The chart compares OEM timing to my modified timing. Thank you Sean Roe, OEM values were sourced from Roe Racing’s VECII documentation . Subsequent to my original post, I tweaked the timing a little more , so I attached an updated chart. It is a great NA tune for my purposes, and hopefully others will find it as a reliable setting for more performance. Here are the details of my VEC II settings:Box Settings: Degrees in loan; % in RPM. I am using the VEC MAP, not the OEM. No particular reason, just happened to be the way I set it up. You can easily set up the same values with the OEM MAP, just set the LOAD tables for WOT, which is essentially no vacuum, or very little. Specifically, set the values in the vacuum tables for the range of -5.00 through 0.00. IGNITION Load Table -5.00 -> 13.00 -2.50 -> 13.00 -0.00 -> 13.00 RPM Table Rpm % 1500 50 2000 30 2500 22 3000 22 3500 45 4000 66 4500 77 5000 56 5500 56 6000 11 FUEL Load Table – Per ROE VEC II documentation. The -4.00 settings come into play during deceleration and decrease ‘popping’. 0.00 -> -4.00 0.16 -> -4.00 I added some WOT fuel since I bumped up timing. -5.00 -> 1.00ms -2.50 -> 3.00ms -0.00 -> 3.00ms RPM Table Rpm % 1000 33 1500 63 2000 72 2500 56 3000 42 3500 31 4000 50 4500 100 5000 100 5500 100 6000 100 6500 100 Post your comments or questions. Rob ![]() 2002 GTS - Sewer Pipe Exhaust with VECII Enhancements and Texas Nitrous Technology 'Insurance Policy' !!! Hope to see you on the NORTH end of the tollway ![]() |
| Viper bar stool and pub table??? | radta7 | Merchandise, Collectibles, Memorabilia, Apparel, and Miniatures | 3 | 11-24-2005 08:53 PM |
| Christina,Get Away From The Buffet Table!!! | Hockeysnake | Sneaky Pete's Place | 19 | 06-25-2003 11:41 PM |
| VOI Table centerpieces AVAILABLE ! | JonB - PartsRack | VCA Viper Events and Gatherings | 3 | 10-18-2002 09:18 AM |
| pictures of rim as a table???? | brettvette | RT/10 and GTS Discussions | 6 | 11-16-2001 04:30 PM |
