Sponsored by: PartsRack.com
Old 10-11-2005, 04:48 PM   #1
Marcus
Default missing a gear while shifting
hey guys, as anyone here ever missed a gear while shifting? I was driving my car and I shifted mistakenly from 4th to 3rd and heared a not so nice sound while engaging the clutch....but I didnt engage it all the way and put it into neutral. Car is good but that sound from under the car scared me...like the tranny moved a bit or something...all is fine, I just hope I didnt f***k anything up.
Marcus is offline   Reply With Quote
Old 10-11-2005, 04:56 PM   #2
Default Re: missing a gear while shifting
did ya over rev it ? ? ? or hit the rev limiter ?
Old 10-11-2005, 04:58 PM   #3
Marcus
i dont think so, I know i didnt go past 5k rpm...just sounded awkward...like if i ran over something....but all appears to be ok...car shifts, and drives fine
Old 10-13-2005, 03:56 AM   #4
Andrew2KRT10
Andrew2KRT10's Avatar
Don't worry it has happened to the best of em. I did it a few times early on at the track. You need to get used to how to position your hand on the shift to reduce the tendency to do that. Not top, but sides.
AC
Andrew2KRT10 is offline   Reply With Quote
Old 11-02-2005, 06:38 PM   #5
Blue Batmobile
Blue Batmobile's Avatar
how about shifting from 1st to 2nd. I found a few times it wouldn't engage right away.
Bat™
Blue Batmobile is offline   Reply With Quote
Old 11-03-2005, 09:33 AM   #6
wormdoggy
wormdoggy's Avatar
Just wondering if you have the stock shifter on? I changed to the short shifter and my changes are crisp and cleaner then stock.
Patrick
wormdoggy is offline   Reply With Quote
Old 11-04-2005, 08:04 PM   #7
NOTV8
Bat™
You still have the "skip shift" engage. You have to get use to it or put a skip shift eliminator. I did it on mine and love it.
NOTV8 is offline   Reply With Quote
Old 06-16-2008, 07:59 AM   #8
sailnfl@comcast.net
FL VCA Member
sailnfl@comcast.net's Avatar
I think I will get the eliminator. They have it at
Viper Generation 1 & 2 Accessories and Parts Products Page 9
they have been good about mail orders, returns etc.
Charlie
sailnfl@comcast.net is offline   Reply With Quote
Old 06-16-2008, 08:13 AM   #9
Kenneth Krieger
Arizona VCA President
Watch that down shifting to the wrong gear! IT happened to my previous Viper on a test drive (after front rotors installed) when the mechanic went hard from 1st to 2nd (Roe S/C'd car!!), and then instead of going into 3rd, went back into 1st. Long story short, back end came around, went out into the desert off I-17 and hit a mequite tree......totaled.......DON'T LET THIS HAPPEN TO YOU!!!
Old 06-17-2008, 09:37 AM   #10
DEKE01
Virginia Maryland VCA Member
DEKE01's Avatar
Someone with more knowledge than me can verify, but I'm told that the rev limiter doesn't kick in on a downshift.
I've hit the limiter a few times on the track when I got too excited about a pass and then suddenly lost power. No problem.
Where I did have a scare is that on my second track event, I accidentally went from 3rd to 2nd instead of 4th while racing down a high speed straight. Not good. But fortunately I caught it before the clutch fully engaged and the revs didn't go much past 6000. No damage done but it could have turned out much worse.
Dan
2004 Black Roadster
2006 "Fly Navy" FE 067/200 Blue/White Coupe
DEKE01 is offline   Reply With Quote
Old 06-17-2008, 02:42 PM   #11
mjorgensen
Woodhouse engine and trans mounts will cure 90% of this and the MGW shifter will cure the other 10%.
Woodhouse Viper Service Mgr.
800-889-1893 work
402-677-2935 cell
Old 06-17-2008, 06:36 PM   #12
ViperTony
ViperTony's Avatar
I can attest to that. I have not missed a shift since installing Woodhouse mounts. Night and day difference. The car feels much stronger and the shifter doesn't rattle. Nice and tight.
The same thing happened to me at Pocono and I saw the RPM go slightly past 6K and the limiter didn't kick in but like you I didn't fully engage the clutch. Luckily my back end didn't kick out and it could've been really bad. I changed my engine mounts right after that event.
WE SAVED TATOR'S DODGE
Old 06-17-2008, 08:06 PM   #13
99 R/T 10
99 R/T 10's Avatar
Ok, did anyone else notice this thread is over 3 years old
Old 06-19-2008, 01:31 PM   #14
FATHERFORD
FATHERFORD's Avatar
The limiter is working, but there is no way to slow the engine down while engaged. The engine can cut fuel all it wants, but it's still conected to the tranny and whatever gear you are in.
Old 06-19-2008, 01:35 PM   #15
Trying to get it to Vipair status.
Tranny pops out of gear when backing and you have to hold it in gear... crazyspeed RT/10 and GTS Discussions 2 10-12-2006 01:21 PM
Shifting in 1st gear JiPi RT/10 and GTS Discussions 3 10-17-2005 10:50 AM
SHIFTING 2nd - 3RD, doesn't wanna go in when shifting fast...WHY venomblue550 RT/10 and GTS Discussions 11 10-14-2004 12:44 AM
HELP Trouble Shifting into First Gear sbkim RT/10 and GTS Discussions 17 08-03-2004 03:30 AM
Noise when shifting in first and second gear, '94. JonB - PartsRack RT/10 and GTS Discussions 0 08-02-2002 11:19 PM
