Go Back   Viper Club of America Discussion Forums > Archives > Interior and Exterior
Interior and Exterior Historic posts relating to stock and modified Viper interior (gages, seats, carpets, interior panels) and exterior (body panels, wings, hard and soft tops, front and side windows, etc.) This is a "read only" archive forum.
Old 11-08-2000, 06:49 AM   #1
94 RT/10 Black MAMBA
Default Hood Weight Problem...More for Jon_B??
Yes I am saying that in the full upright position it won't stay up. It's seems almost perfectly balanced with the bias toward falling closed. Where are the adjustments for it? As I look at the hinges I only see non-adjustable springs (or are they adjustable). I need to buy that service manual.
As far as fit and finish it looks GREAT! I couldn't be happier and I thank Dodge for replacing it. If you have this problem I would find a good dealer who will support you and go for it. The only qualm I have is will this hurt the future value as far as originality is concerned. Cetainly the '96 hood should be better with no risk of cracking in the future.
94 RT/10 Black MAMBA is offline   Reply With Quote
Old 11-08-2000, 01:43 PM   #2
Default Re: Hood Weight Problem...More for Jon_B??
Since my last post the dealer has called and told me that there is a different part number for the '96 hood spring. Apparently there is a difference in the weight!
Old 11-09-2000, 07:36 AM   #3
Jon_B... you never cease to amaze! The dealer called me back and guess what? There is no difference in weights after all. Now I'm back to wondering what is wrong with my hood and how to fix it. Any ideas?
Old 11-11-2000, 02:37 AM   #4
RoyV101621
RoyV101621's Avatar
I had the hood replaced on my '94 with a newer hood in 1997. All I can tell yoou is that I got home, raised the hood, called the dealer and installed new springs. There maybe something to this.
RoyV101621 is offline   Reply With Quote
Hood Closing Problem 2BADD 4U RT/10 and GTS Discussions 8 12-26-2004 11:13 PM
OK Jon_B, did the "Wax Dyno" thingy......Results were 94 RT/10 Black MAMBA Archive Management 2 06-30-2001 10:26 AM
Help, Hood Problem Baddasp Archive Management 2 01-30-2001 04:40 PM
Help, Hood problem Baddasp Archive Management 2 01-07-2001 07:49 PM
Hood Weight - I've had a 1996 RT/10 hood 94 RT/10 Black MAMBA Interior and Exterior 2 11-07-2000 07:14 PM
