Go Back   Viper Club of America Discussion Forums > Archives > Interior and Exterior
Interior and Exterior Historic posts relating to stock and modified Viper interior (gages, seats, carpets, interior panels) and exterior (body panels, wings, hard and soft tops, front and side windows, etc.) This is a "read only" archive forum.
Old 11-13-2000, 12:00 AM   #1
John's 1995 Venom 550
Default How to change a side sill?
Just wondering if there is a book you could recommend - like a how to - to fix (or take apart) the 1995 RT/10 for minor changes. Currently I had a scratch drivers side sidesill and would like to know how to change it for a new one or if is possible to repair the sidesill. Does Dodge still sell this part and for how much? Or is it better to get it elsewhere, if so where?
Thanks,
John
John's 1995 Venom 550 is offline   Reply With Quote
Old 11-13-2000, 07:03 PM   #2
Ulysses
Default Re: How to change a side sill?
If you decide to remove them yourself, watch out for the sharp edges.
Old 11-14-2000, 12:00 AM   #3
Jerry Scott[CO]
Jerry Scott[CO]'s Avatar
They are very easy to remove. Remove the four hole plugs in the door with a very thin putty knife. They have release tabs 180 deg apart, so just slide the knife under the edge of the plug and lift gently. The one under the door is a little tougher to get out, so just take your time. If you break one, just buy a new one at Pep Boys or pay the price at Dodge. There are 10 sheet metal screws to be removed, 6 on top and 4 on the bottom. After the screws are out, start pulling outward and it should come off. This is the way that the GTS comes off and I think that the RT/10 is the same.
They are very expensive to replace, so just take it to a body shop for repair. There were some used ones for sale on the Parts For Sale list under Classified on the VCA home page, for around $1000 ea..
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Jerry Scott[CO] on November 13, 2000 at 13:03</font>
Jerry Scott[CO] is offline   Reply With Quote
Toasted Side Sill ViperJoe RT/10 and GTS Discussions 20 06-01-2006 08:17 AM
Help, need pic of side sill 94RT10Ohio RT/10 and GTS Discussions 4 05-27-2006 06:50 AM
Side Sill Insulation for GEN I Side exhaust ViperJames RT/10 and GTS Discussions 5 10-07-2005 05:39 PM
Side sill? SMCBUILDERSINC RT/10 and GTS Discussions 2 09-18-2004 10:57 AM
Anyone Have a Side Sill For 01 RT? Dimitrios RT/10 and GTS Discussions 3 07-16-2004 09:01 AM
