Go Back   Viper Club of America Discussion Forums > General Viper Forums > Merchandise, Collectibles, Memorabilia, Apparel, and Miniatures
Merchandise, Collectibles, Memorabilia, Apparel, and Miniatures Discuss your Viper Collectible, die-cast miniature, fine art, jewelry, memorabilia, and apparel finds!
Old 09-03-2006, 12:36 AM   #16
Blue Batmobile
Blue Batmobile's Avatar
Default Re: Insane,bad and radical 1/18 inside....
I'm impressed
Bat™
Blue Batmobile is offline   Reply With Quote
Old 09-04-2006, 12:50 PM   #17
le66
Hello! So many thanks for yours pics!!...
But your red and black SRT is a little spécial,I would post you something witch should you like...promised! Chris.
le66 is offline   Reply With Quote
Old 09-04-2006, 12:59 PM   #18
le66
Here is a RT-10 Burago that I received little horrible time ago (on Ebay...At start I buy it for parts...)...bad painting,bad condition,I should will post his rebuilding supplements...Chris.
Old 09-05-2006, 12:19 PM   #19
le66
So,I promise you some pics of RT-10 when I received it...
don't be afraid....
After several days,here you are a new Viper...
It's a little better than the first no?
I explain you how I do,it's not very hard...
Old 09-08-2006, 10:48 AM   #20
le66
Hello!!
As promised,I summarise you the building of the RT-10,its name is "Wonder"Project",and she's built for a friend...
For the first stage,all is dismounted
Old 09-08-2006, 10:54 AM   #21
le66
To make disappear old painting, I sandpaper all the body with the sandpaper n°600,rather fine paper tu use with water,as in traditional body:
Old 09-08-2006, 11:01 AM   #22
le66
You take your body....
that you dismonut...
I start with the front cap...
Old 09-08-2006, 11:04 AM   #23
le66
....then the back trunk...
Old 09-08-2006, 11:07 AM   #24
le66
And the arch of safety...
Old 09-08-2006, 11:10 AM   #25
le66
And the two doors...
Old 09-08-2006, 11:16 AM   #26
le66
Then you finish by the frame...
One hour should be counted thirty minutes to do a good work...
If as me you've sandpaper with water,clean well and do let dry,the body should not be wet,one passes to painting...
Old 09-08-2006, 11:26 AM   #27
le66
I choose a black metalik TAMIYA like basic painting,n° TS-40
two bombs are necessary...
Old 09-08-2006, 11:32 AM   #28
le66
I started with the front cap,below...
Old 09-08-2006, 11:44 AM   #29
le66
Then,I took a bomb of white finish (gray clearly it's so good also...) an I made the lower part of the arch of the safety...
You wait 5 minutes and you put a metalik layer of black at once...
You let dry...
Old 09-08-2006, 11:51 AM   #30
le66
After having to slightly sandpaper the onterior of the 2 doors,you pu on a black veil of painting...
the same operation with the back trunk...
You let dry too...
« VOI 8 | - »
This car is insane!!! unclgreggy SRT10 and SRT10 Coupe Discussions 64 02-13-2008 09:57 AM
Modified Radical SR3 - 1100pounds/ 275HP Bobpantax Driven 0 02-17-2007 01:47 PM
Are Vipers too radical for most people?? Ianfl SRT10 and SRT10 Coupe Discussions 66 09-23-2003 09:59 AM
CHECK THIS OUT - Radical SR3 - PICTURES ADDED onerareviper Sneaky Pete's Place 3 05-16-2002 11:46 PM
Are you insane?? snowmann Sneaky Pete's Place 4 01-16-2002 07:29 AM
