Sponsored by: PartsRack.com
Old 11-30-2000, 06:11 PM   #1
Tom Welch
Tom Welch's Avatar
Default Re: How to paint rims to match yellow body?
Tadek,
I have a viper that was one of only 14 produced with those yellow wheels in 1997. I recently bought a second set of wheels and had them painted to match. They came out perfect and i have had no problems with the paint holding up against washing, brake dust, high speed, high temps, etc.
If you want to email me i can give you the number of the body shop that did the work and they can do them for you or give you the type of primers and paint needed to make paint stick to aluminum.
The key ingredient in the process is the preparation and priming of the surface, i believe it is called an "etching" primer(im not familiar with the process of painting)
They used one of my wheel caps for computer paint matching. Your cars color code will provide the same information.
good luck
tom
"keep the lipstick off the dipstick"
Tom Welch is offline   Reply With Quote
Old 11-30-2000, 10:07 PM   #2
Paul Ronald
VCA Member WA
Paul Ronald's Avatar
Awww...Tony- make um BLACK!!! That hides the brake dust!!!
On your car.... the black will accent the stripes!!
Paul Ronald is offline   Reply With Quote
Old 12-01-2007, 04:03 PM   #3
OceanPalm7
NM VCA Member
I own a 2006 SRT 10 Blue Convertible... Recently I took off the
tire to clean for a car show... What is the lug nut torque in lbs. Discount tire tells me 100 lbs. The dealership dells me 92 lbs... Thanks for your reply..
OceanPalm7
OceanPalm7 is offline   Reply With Quote
Old 12-03-2007, 12:22 AM   #4
B767DRIVER
B767DRIVER's Avatar
OceanPalm7
90-95 lbs...
'06 First Edition 194/200
B767DRIVER is offline   Reply With Quote
Factory Paint Match? BlackGTS RT/10 and GTS Discussions 16 04-30-2006 07:09 PM
Need paint code or match for Gen. 1 interior Gray fuzzy paint? SHADOW RT/10 and GTS Discussions 6 08-08-2005 12:38 PM
Gen I Interior trim black paint match?? MAMBA RT/10 and GTS Discussions 1 04-04-2005 08:26 PM
do a paint code match? STUGOTS RT/10 and GTS Discussions 7 04-08-2004 10:00 AM
anyone got their door stansion cover PAINTED match body color??? venomblue550 RT/10 and GTS Discussions 3 12-14-2003 08:48 PM
