Sponsored by: PartsRack.com
Old 11-24-2007, 06:22 PM   #1
srt4dubz
Default OBD1 Vs. OBD2
Alrighty ... so for power future ... would a 96 and up obd2 car be a much better investment ... or would an rt10 like a 1994 or something be just as capable.
I know the benifits of OBD2 but with this v10 ... little different story maybe
srt4dubz is offline   Reply With Quote
Old 11-25-2007, 06:33 AM   #2
Default Re: OBD1 Vs. OBD2
There is a lot more to say about the difference of a Gen 1 car to a Gen 2 car than just OBD.
You're the first I've ever seen bring that up as a selection criteria.
Old 11-25-2007, 07:58 AM   #3
mangle
Just a thought... If you plan to do extensive modifications, you may want to go with an OBD-II car for emissions testing concerns. It's much easier to trick the computer in to reporting a healthy emissions system via the OBD-II port than it is to make the exhaust clean enough to pass a sniffer test. Then again, if you have a fuel/ignition map specifically for emissions testing, you may be able to get away with an older car. (This is assuming that you live somewhere with emissions testing and that they do a plug test for OBD-II and a sniffer on a dyno for pre-96 cars.)
mangle is offline   Reply With Quote
Old 11-25-2007, 01:11 PM   #4
Viper Wizard
Viper Wizard's Avatar
Cool Re: OBD1 Vs. OBD2
Forget about that OBDII crap! Go with a GENI OBDI Viper, then you wont have to worry about emission testing and fooling a cumputer ! It is after all a true "roadster" and a REAL Viper! GENI motors are beefier then a GENII motors once you take care of the head gaskets! ie. cross bolt crank shaft, forged rods, forged pistons, bigger head bolt! We don't need no stinking emission!!
"My 2-cents"
Do a search here on this topic.
CHUCK TATOR
1975-USAF/SAC/KC-135/FB-111
NRA Life Member
Viper Tech Since 1993
Viper Owner 94/RT#902
TATOR'S DODGE SINCE 1914!
Old 11-25-2007, 01:19 PM   #5
grcforce327
"My 2-cents"
I'll add my two pennies too!!!Anyone got change for a nickel???
Old 11-25-2007, 01:39 PM   #6
2snakes4us
Kansas City VCA Member
2snakes4us's Avatar
"My 2-cents"
Here ..Here !! I agree.
The harder you work for it...the more you appreciate it.
Stock 94 RT/10
Stock 02 GTS FE #72
2snakes4us is offline   Reply With Quote
Old 11-25-2007, 07:39 PM   #7
srt4dubz
Alrighty ... its not a selection issue .. its just a question I was wondering about ... and I had to see what some guys had to say ... Question has been answered
thanks
Old 12-08-2007, 09:15 PM   #8
kcobean
kcobean's Avatar
"My 2-cents"
Something I've always wondered Chuck; if the Gen-1 motor is so much beefier than the Gen-2 motors (particularly the 00 and later Gen-2's) why do the Gen-2's make more power from the factory (Gen-1's are 400 BHP, right? 1996 went to 415/450 for the RT10/GTS respectively, and then the RT10 went to 450 in 97, per the IVR). Was it all about the tune they were given? Different Cam? Enlighten us, oh wise and powerful Wizard!
Proud VA/MD VCA Member
2001 ACR Bumblebee
2007 Charger SRT8 SuperBee
Old 12-09-2007, 09:04 AM   #9
Viper Wizard
Yes, cam and tune made the defference.
CHUCK TATOR
NRA Life Member
anyone got a list of OBD2 codes ? or know where to DL ? plumcrazy RT/10 and GTS Discussions 2 04-30-2006 02:58 AM
BEST OBD2 logger ? Schulmann RT/10 and GTS Discussions 0 05-07-2005 07:47 PM
Where is the OBD2, or DLC found? 2000GTS RT/10 and GTS Discussions 3 12-11-2004 07:04 PM
