Sponsored by: PartsRack.com
Old 04-10-2008, 12:40 PM   #1
Chris Thomas
MI VCA Member
Default New owner engine Qustion
New viper club member and owner looking for seasoned advice from the long time owners. I purchased a 2000 Viper and I noticed the engine has a rough idle worst at times Ive owned other V-10s but not a Viper. Is this a normal for the Vipers. Thanks
Chris Thomas is offline   Reply With Quote
Old 04-10-2008, 12:51 PM   #2
goldcup
Kansas City VCA Member
goldcup's Avatar
Default Re: New owner engine Qustion
I am no mechanic but has the battery been replace recently?
Many times it can take a while for the computer to relearn
I believe the technique is after hooking battery up you press accelerator to the floor twice with the ignition on (before starting)
Someone will chime in that knows more than me.
Old 04-10-2008, 01:06 PM   #3
adamlotus
very normal .if you get a ck eng light on than not,but otherwise it ha sa lumpy cam.
adamlotus is offline   Reply With Quote
Old 04-10-2008, 01:17 PM   #4
I thought the cam was on forged engines? Prior to 2000.
Old 04-10-2008, 01:31 PM   #5
ViperGTS
VCA Member Bavaria
ViperGTS's Avatar
>>>other V-10s but not a Viper<<<
Audi, Lambo, BMW,...
you cant compare, really...take the car to a good dealership or to a local Viperclub meeting to check
www.viperclub.de
- no speed limit -
Old 04-10-2008, 02:56 PM   #6
Chris Thomas
MI VCA Member
I bought the Viper November 07 and put in storage for the winter the batter was propbably low because I did just replace it this week, it was dead. I will try your technique. I will take it to a dealer shortly just to make sure everthing is in good operating order. I was going to take it to Dick Scott Dodge in Plymouth Mi. unless anyone has a better location. Iam in Bay City Mi. Thanks for the feed back !!
Old 04-10-2008, 02:58 PM   #7
Roadrunner
Also make sure you have fresh gas... like from this year... gas ages quickly, and looses the "light ends" which help with idle stability. Also check your plugs, sooty plugs from running to gently will hurt idle stability as well.
Some roughness is to be expected though... nature of the beast.
Roadrunner is offline   Reply With Quote
Old 04-11-2008, 12:27 PM   #8
RobZilla
Florida VCA Member
RobZilla's Avatar
My 2000 has a rough idle... not quite as noticable as other vipers Ive been in. From my experience it's normal. If it gets really rough or progressive then maybe you have an issue. Im not a mechanic either but I would assume all V10's would rumble.
'00 Black RT/10 - - B&B Headers, Cat Delete, Corsa CatBack Exhaust, '06 Tranny, K&N,
Smooth Tubes, Poly Mounts, Vec II, HID's, Short Throw Shifter, Chromoly Flywheel
Newbie Owner Looking for Previous Owner Black Moon New Owner Questions 0 12-29-2007 12:46 PM
Fuel rails for 2000 gts qustion pullshard RT/10 and GTS Discussions 0 05-26-2004 05:44 PM
Ferrari owner + RX7 owner = 2 morons racing FranciscoR. Sneaky Pete's Place 4 10-08-2003 03:29 PM
Supra Owner to Viper Owner cirus RT/10 and GTS Discussions 14 04-19-2002 05:34 AM
VETTE OWNER, FUTURE VIPER OWNER NEEDS YOUR HELP!!!! JBS99HT RT/10 and GTS Discussions 26 12-11-2001 09:52 PM
