Sponsored by: PartsRack.com
Old 05-13-2008, 02:59 PM   #1
Vipuronr
Vipuronr's Avatar
Default RT/10 Top A Pain, Now Add To That The Back Window
Okay, now I'm beginning to think this RT/10 is just a cover for a high school regents exam!
How DO you lock the rear window in place. I put the key in and turned it easy enough, but cannot turn it once the piece hits the slot. I thought a sledge hammer and chisel might help, but then thought better of it!!! I already tried, moving the window to the left and right, trying to find that "sweet spot." But, to no avail...not happening, no way, nada, nien, niet and so on.
So, how does the window lock without me breaking something while trying???? Or, do I drive with the side windows closed all the time, for fear of the back window flying out and hitting a car in back of me
Help!!!!
All I wanna do is driveeeeeeeeeee
Peter
FIREFIGHTERS SAVE LIVES AND PROPERTY
SUPPORT TATORS DODGE!!!!!!!!!!!!!!!!
Vipuronr is offline   Reply With Quote
Old 05-13-2008, 03:07 PM   #2
LiquoRT/10
LiquoRT/10's Avatar
Default Re: RT/10 Top A Pain, Now Add To That The Back Window
Try going up and down or forward and back. The gasket must be getting old. Don't drive with it if its not locked.
2000 RT/10
LONG LIVE TATORS DODGE !!!!!!!!!!!!
LiquoRT/10 is offline   Reply With Quote
Old 05-13-2008, 03:15 PM   #3
CitySnake
NY/CT VCA President
CitySnake's Avatar
The lock is simple enough....the key turns a cylinder "arm" that fits into a "notch". If the key is not turning, put some pressure on the window to move it either forward or back to line up the notch with the arm. When it's lined up, it will easily slide right in. Don't force it.
...But you can call me City.
2001 RT/10
2008 SRT (awaiting delivery)
WE SAVED TATORS DODGE
CitySnake is offline   Reply With Quote
Old 05-13-2008, 04:11 PM   #4
Venomiss
Kansas City VCA Member
Venomiss's Avatar
Does anyone have some pictures for him??
Venomiss is offline   Reply With Quote
Old 05-13-2008, 08:47 PM   #5
Vipuronr
Vipuronr's Avatar
Thanks everyone...yes, tried to move up, down, back and forth, now side to side....hey, sounds like some kinda dance.
But seriously, I did try moving it in all directions to line up the arm with the slot. I got it to go part way into the slot but no more. Clearly, I don't want to force it, so not sure what to do....here again, think I'm going to "ask Chuck" when I bring in the car. I may play a little more, but if I can't get it to work, then I'll just wait.
Actually, I just wanna drive
Thanks all.
Peter
1998 RT/10, Red (5k Miles)
Old 05-14-2008, 07:45 AM   #6
LiquoRT/10
LiquoRT/10's Avatar
If your car is garage kept, leave it off. I took mine off in the spring and won't put it on again until fall. Just go drive......
2000 RT/10
Old 05-14-2008, 08:43 AM   #7
Vipuronr
Vipuronr's Avatar
Yes, garaged, but I still have the issue of not being able to get the rear latches on the soft top open!!!
After my service at Tator's (24th), I'll just leave everything off...but still do need to make sure the window goes in an locks.
Thanks for the advice.
Peter
Old 05-14-2008, 09:22 AM   #8
ViperTony
ViperTony's Avatar
Here's a mini How To in soft top removal for a GenII:
This is the latch mechanism (two of them) that holds down the rear of the soft top. Notice the clothespin-type mechanism. This latch slides over a pin located in the sports-bar:
The sports-bar is the black piece that runs behind your head when you're seated in the Viper. It has two slots on either side to accommodate the soft-top latches. The latches slide into these slots:
From inside your Viper, you can see the latch inserted through the sportspad, it looks something like this:
When the latch is engaged, it's latched onto a steel pin found inside this slot in your sport pad:
To disengage the latch from the pin, use a finger to pull the latch lever toward you:
If pulling that lever is difficult, then the top is on too tight. Push down on the top (over the latch area) while pulling the lever and it disengage:
Don't forget to do the same on the other side.
Don't forget the front. Just pull the lever until is says "Unlatched":
My top was on too tight originally and I had a difficult time unlatching the rear. In the first pic showing the latch, you'll see two screws. You can looses these screws and adjust the height of the latch to make the fit looser or tighter. I loosened it about 1/4" and it fits like a glove now.
Hope this helps.
- Tony
WE SAVED TATOR'S DODGE
Old 05-14-2008, 01:33 PM   #9
Vipuronr
Vipuronr's Avatar
Hi tony:
Thanks for the detail and the pics. I will have to look again to see if I can figure it out. When I looked at the rear latch, it was inside part of the frame of the top...not sure how to explain that. So, it was very difficult to get my hands in to see what and how I was supposed to open.
I wasn't sure how you shot the photo showing the latch engaged on the pin. I looked under the sports bar and did not see any opening. If I am supposed to open the latch from around the pin (which is under under the slot, don't know what I move or squeeze to do that.
Hard to describe, how you understand. I'm sure it is easy once you know, but as I've said before, this car is not exactly user friendly.
Thanks again, will check when I get home.
Peter
Old 05-14-2008, 03:54 PM   #10
mike & juli
mike & juli's Avatar
Tony: GREAT write-up and illustrations!!! (Tho confusing to me, as I haven't seen the full inside of an RT) You are GREAT to try to help Peter out!~~~juli
Black '05 SRT vert w/mods
Red '08 Paddle-Shifting Vette
Old 05-14-2008, 04:17 PM   #11
ViperTony
ViperTony's Avatar
Originally Posted by Vipuronr View Post
Hi tony:
From the driver's side, stick your head in the car and look at the back window. Actually, look up where the rear of the top meets to the top of the car. You should see a slot where the latch hooks into. Stick your finger in there and feel for the latch.
The 'inside' pics were taken from inside the car looking upward where the top meets with top of the car or sportspad. This is the area behind you, inside the cockpit, where the rear brake light is located above the rear window. Do as pic illustrates...take your finger and try to move the latch so it disengages. If it's not cooperating, push down on the top at the same time you try to slide the latch.
The car itself is user friendly, one of the easiest cars I've ever worked on. The problem is the soft top. It's an afterthought and could've been designed better but it is what it is. You're going through a learning curve. Once you've got it off/on a couple of times you'll get the hang of it. The fun part is unfolding the top...but we'll save that for later.
Peter
See my comments above. - Tony
Old 05-14-2008, 04:19 PM   #12
ViperTony
ViperTony's Avatar
By far the soft top on the GenIII is awesome. Dimitrios enjoys showing me how easy it is to open and close his soft top on the GenIII. I'm sure I'll get another demonstration from him on Sunday as it will be a joy working the soft top if it rains.
Tinting Back Window RT/10 BJ MOTORS RT/10 and GTS Discussions 12 12-12-2003 04:04 AM
my back pain remedies remster Sneaky Pete's Place 13 09-08-2002 04:08 PM
Driver's window will not go back up. MichaelP RT/10 and GTS Discussions 4 07-03-2002 09:57 AM
BACK WINDOW OF RT10? SPARKY RT/10 and GTS Discussions 12 06-13-2002 07:32 AM
TINT Back Window RT/10? GaryA RT/10 and GTS Discussions 7 03-12-2002 04:10 PM
