| New Owner Questions Great questions from the past and the chance to ask new ones too! Sponsored by: PartsRack.com |
Okay, now I'm beginning to think this RT/10 is just a cover for a high school regents exam!
![]() How DO you lock the rear window in place. I put the key in and turned it easy enough, but cannot turn it once the piece hits the slot. I thought a sledge hammer and chisel might help, but then thought better of it!!! I already tried, moving the window to the left and right, trying to find that "sweet spot." But, to no avail...not happening, no way, nada, nien, niet and so on.![]() So, how does the window lock without me breaking something while trying???? Or, do I drive with the side windows closed all the time, for fear of the back window flying out and hitting a car in back of me ![]() Help!!!! ![]() All I wanna do is driveeeeeeeeeee ![]() ![]() ![]() ![]() Peter __________________ FIREFIGHTERS SAVE LIVES AND PROPERTY![]() SUPPORT TATORS DODGE!!!!!!!!!!!!!!!! |
Try going up and down or forward and back. The gasket must be getting old. Don't drive with it if its not locked.
2000 RT/10 LONG LIVE TATORS DODGE !!!!!!!!!!!! |
The lock is simple enough....the key turns a cylinder "arm" that fits into a "notch". If the key is not turning, put some pressure on the window to move it either forward or back to line up the notch with the arm. When it's lined up, it will easily slide right in. Don't force it.
...But you can call me City. ![]() 2001 RT/10 2008 SRT (awaiting delivery) WE SAVED TATORS DODGE
Does anyone have some pictures for him??
Thanks everyone...yes, tried to move up, down, back and forth, now side to side....hey, sounds like some kinda dance.
![]() But seriously, I did try moving it in all directions to line up the arm with the slot. I got it to go part way into the slot but no more. Clearly, I don't want to force it, so not sure what to do....here again, think I'm going to "ask Chuck" when I bring in the car. I may play a little more, but if I can't get it to work, then I'll just wait. ![]() Actually, I just wanna drive ![]() ![]() ![]() ![]() Thanks all. Peter __________________ 1998 RT/10, Red (5k Miles) FIREFIGHTERS SAVE LIVES AND PROPERTY![]() SUPPORT TATORS DODGE!!!!!!!!!!!!!!!! |
If your car is garage kept, leave it off. I took mine off in the spring and won't put it on again until fall. Just go drive......
Yes, garaged, but I still have the issue of not being able to get the rear latches on the soft top open!!!
![]() After my service at Tator's (24th), I'll just leave everything off...but still do need to make sure the window goes in an locks. Thanks for the advice. ![]() Peter __________________ 1998 RT/10, Red (5k Miles) FIREFIGHTERS SAVE LIVES AND PROPERTY![]() SUPPORT TATORS DODGE!!!!!!!!!!!!!!!! |
Here's a mini How To in soft top removal for a GenII:
This is the latch mechanism (two of them) that holds down the rear of the soft top. Notice the clothespin-type mechanism. This latch slides over a pin located in the sports-bar: ![]() The sports-bar is the black piece that runs behind your head when you're seated in the Viper. It has two slots on either side to accommodate the soft-top latches. The latches slide into these slots: ![]() From inside your Viper, you can see the latch inserted through the sportspad, it looks something like this: ![]() When the latch is engaged, it's latched onto a steel pin found inside this slot in your sport pad: ![]() To disengage the latch from the pin, use a finger to pull the latch lever toward you: ![]() If pulling that lever is difficult, then the top is on too tight. Push down on the top (over the latch area) while pulling the lever and it disengage: ![]() Don't forget to do the same on the other side. Don't forget the front. Just pull the lever until is says "Unlatched": ![]() My top was on too tight originally and I had a difficult time unlatching the rear. In the first pic showing the latch, you'll see two screws. You can looses these screws and adjust the height of the latch to make the fit looser or tighter. I loosened it about 1/4" and it fits like a glove now. Hope this helps. - Tony
WE SAVED TATOR'S DODGE ![]() Last edited by ViperTony; 05-14-2008 at 09:29 AM. |
Hi tony:
Thanks for the detail and the pics. I will have to look again to see if I can figure it out. When I looked at the rear latch, it was inside part of the frame of the top...not sure how to explain that. So, it was very difficult to get my hands in to see what and how I was supposed to open. I wasn't sure how you shot the photo showing the latch engaged on the pin. I looked under the sports bar and did not see any opening. If I am supposed to open the latch from around the pin (which is under under the slot, don't know what I move or squeeze to do that. Hard to describe, how you understand. I'm sure it is easy once you know, but as I've said before, this car is not exactly user friendly. ![]() Thanks again, will check when I get home. Peter __________________ 1998 RT/10, Red (5k Miles) FIREFIGHTERS SAVE LIVES AND PROPERTY![]() SUPPORT TATORS DODGE!!!!!!!!!!!!!!!! |
Tony: GREAT write-up and illustrations!!! (Tho confusing to me, as I haven't seen the full inside of an RT) You are GREAT to try to help Peter out!~~~juli
Black '05 SRT vert w/mods Red '08 Paddle-Shifting Vette
#11 | |
By far the soft top on the GenIII is awesome. Dimitrios enjoys showing me how easy it is to open and close his soft top on the GenIII. I'm sure I'll get another demonstration from him on Sunday as it will be a joy working the soft top if it rains.
| Tinting Back Window RT/10 | BJ MOTORS | RT/10 and GTS Discussions | 12 | 12-12-2003 04:04 AM |
| my back pain remedies | remster | Sneaky Pete's Place | 13 | 09-08-2002 04:08 PM |
| Driver's window will not go back up. | MichaelP | RT/10 and GTS Discussions | 4 | 07-03-2002 09:57 AM |
| BACK WINDOW OF RT10? | SPARKY | RT/10 and GTS Discussions | 12 | 06-13-2002 07:32 AM |
| TINT Back Window RT/10? | GaryA | RT/10 and GTS Discussions | 7 | 03-12-2002 04:10 PM |
