Old 04-11-2008, 10:03 AM   #1
Sean Roe
Site Sponsor
Sean Roe's Avatar
Default Re: Group Buy On SCT Handheld Flash Programmers
Hi Everyone,
We have a thread going in the Group Buy section, but I've received multiple emails and a couple PM's that people can't reply in the thread.
Here's a link to it:
I'd like to switch it over to this forum instead.
If anyone has any questions, or would like to start a running list, this is may be a better place to do it.
If you want to be on the "interest" list, please copy below, add your forum name a post. The next person would add theirs and so on until we see how many people are interested. The end number will determine the discount level. It just can't go below $500.
SCT Group Buy Interest:
1. Name : Year / Model
Old 04-11-2008, 10:11 AM   #2
2K6VOI9
Northern CA VCA Member
2K6VOI9's Avatar
Name : Year / Model
1. 2k6voi9 2006/Coupe
2006 Viper SRT-10 Coupe
Ninth Viper Owners Invitational (VOI9)
Made in the USA
2K6VOI9 is offline   Reply With Quote
Old 04-11-2008, 10:12 AM   #3
FE 065
Name : Year / Model
2. FE 065 : '01 ACR
Old 04-11-2008, 02:46 PM   #4
Parisianviper
France VCA Member
Parisianviper: 01 RT/10
Parisianviper is offline   Reply With Quote
Old 04-11-2008, 07:22 PM   #5
radta7
Illinois VCA Member
radta7's Avatar
what's a typical increase on a 97 with headers, exhaust, rt cats, smooth tubes and filters?
radta7 is offline   Reply With Quote
Old 04-11-2008, 08:51 PM   #6
Chuck Greggs, S Arizona ACR
'99 ACR
Chuck Greggs, S Arizona ACR is offline   Reply With Quote
Old 04-12-2008, 08:48 AM   #7
CROM
CROM's Avatar
1. 2k6voi9, '06 Coupe
2. FE 065, '01 ACR
3. Parisianviper, 01 RT/10
4. Chuck Greggs S Arizona ACR, ACR
5. Canyon707, 99ACR
6. CROM, 98 GTS
98 Red GTS - Mods
98 Red GTS - SOLD
Old 04-12-2008, 05:19 PM   #8
viperflex
Illinois VCA Member
Viperflex: 2004
viperflex is offline   Reply With Quote
Old 04-12-2008, 08:57 PM   #9
CROM
CROM's Avatar
For those who can't read:
2. FE 065, '01 ACR
5. Canyon707, 99ACR
6. CROM, 98 GTS
7. viperflex, 2004
98 Red GTS - Mods
98 Red GTS - SOLD
Old 04-13-2008, 08:50 PM   #10
281cammer
2. FE 065, '01 ACR
5. Canyon707, 99ACR
6. CROM, 98 GTS
7. viperflex, 2004
8. 281cammer 01 GTS
281cammer is offline   Reply With Quote
Old 04-14-2008, 04:07 PM   #11
Sean Roe
Site Sponsor
Sean Roe's Avatar
I'm not sure what octane of gasoline you're using, but it can vary.
Basically, the HP gains come from two factors.
#1. Making the air / fuel ratio flat and ideal.
#2. Optimizing ignition timing for the gasoline you're using.
The farther the A/F and timing are from ideal, the larger the gains. If you've done a lot to increase air flow and are on 91 octane fuel, the gain will be smaller as you can't run as much ignition advance and the increase in air flow automatically improves the otherwise excessively rich AF ratio above 4,000 RPM.
Here's a typical stock Gen3 using 93 octane. Only mods before flashing were Mopar cat-back and high flow S&B air filters. This is about what one would typically expect on either Gen2 or 3. Sometimes more is gained at lower RPM when the engine is running too lean there. A larger torque gain can result from adding the fuel needed.
Old 04-14-2008, 06:50 PM   #12
CROM
CROM's Avatar
SCT Group Buy Interest: (Pulled some from the other post)
2. FE 065, '01 ACR
5. Canyon707, 99ACR
6. CROM, 98 GTS
7. viperflex, 2004
8. 281cammer 01 GTS
9. Dimitrios, 05 SRT
10. ViperVon, RT/10 Year?
11. MTGTS, 01? GTS
98 Red GTS - Mods
98 Red GTS - SOLD
Old 04-15-2008, 07:45 AM   #13
FE 065
If you've done a lot to increase air flow and are on 91 octane fuel, the gain will be smaller as you can't run as much ignition advance and the increase in air flow automatically improves the otherwise excessively rich AF ratio above 4,000 RPM...
I've made a number of changes to increase airflow, and Sean's comments have me concerned about the actual gains I might get with the SCT. I'm going to take my name of the list for now while I think it over and maybe contact Sean again..I might jump back on before the deadline.
2. Parisianviper, 01 RT/10
3. Chuck Greggs S Arizona ACR, ACR
4. Canyon707, 99ACR
5. CROM, 98 GTS
6. viperflex, 2004
7. 281cammer 01 GTS
8. Dimitrios, 05 SRT
9. ViperVon, RT/10 Year?
10. MTGTS, 01? GTS
Old 04-15-2008, 12:45 PM   #14
Sean Roe
Site Sponsor
Sean Roe's Avatar
Keep in mind that we don't put the same tune in all the boxes. We set the program according to the modifications. If headers have been added for example, we add more fuel, primarily above 4,000 RPM where the headers have the larger impact.
The statement about the AF changing with modifications is 100% relative to the gains to be had. The closer a tune is to ideal, the less there is to be gained with changing it.
If you have time, it's always best to dyno and see where your engine stands in regard to AF and power numbers.
Old 04-15-2008, 01:06 PM   #15
Dimitrios
Dimitrios's Avatar
20-30 rwhp gain for $509 is totally do-able. ill take one!
have K&N instake w filters and corsa catback and RTech hi-flo cats. should i dyno and ge AF ratios first?
Ab's quality wires, 3" Corsa, Eibach Springs
K&N Cold Air, ROE SCT Flash
513 RWHP - 569 TQ
Dimitrios is offline   Reply With Quote
Group Buy On SCT Handheld Flash Programmers Sean Roe Special Group Buys 25 04-16-2008 01:35 PM
For those with SCT Programmers. DC Performance Performance Modifications 8 03-07-2008 08:24 AM
Plug in flash programmers for 1996 to 2002 now in stock Sean Roe New Products, Supplier Specials, and Group Buys 16 11-19-2007 05:43 PM
Anyone using the new handheld programmers yet? dave6666 RT/10 and GTS Discussions 4 11-01-2007 09:49 AM
Nology.com handheld dyno? WESTCOAST JASON Performance Modifications 0 03-18-2003 08:01 PM
