Old 05-18-2008, 12:26 PM   #1
Sean Roe
Site Sponsor
Sean Roe's Avatar
Default Fuel Injector Set w/Connectors, 92-02 Vipers, 60 lb/hr @ 55 psi
Fuel Injector Set w/Connectors - 92-02 Vipers - 60 lb/hr @ 55 psi - Air & Fuel Delivery - Roe Racing
Are your stock injectors not putting out enough fuel for your supercharged, turbo'd or head & cam engine? Worried about running lean and hurting your engine? Here is your answer! Don’t spend thousands on new fuel rails and top feed injectors when these side feed injectors are rated for 60 lb/hr at 55 psi (stock fuel pressure). Sold as a set of 10 injectors with connectors.
Price: $740.00
Product Details Until now, if your 1992-2002 Viper engine was putting out serious power, your only solution for bigger injectors was to add an expensive set of fuel rails and install bigger top feed injectors, typically at a cost of around $2000. This replacement set of side feed fuel injectors have been modified to fit into the stock 1992-2002 Viper intake manifolds. These are rated at the stock resistance of 12.5 ohms so an additional “load box” will not be needed. We also include new fuel injector connectors with metal clips that are far superior to the stock, all-plastic clips that often became weak over time loosing their electrical connection. COMPARISON : GEN1 stock injectors are rated at 25 lb/hr @ 55 psi and GEN2 stock injectors are rated at 29 lb/hr @ 55 psi. NOTE : Tuning will most likely be needed to obtain maximum horsepower output when adding these injectors. Picture shown of single injector before modification.
Replacing Injector connectors on Roe SC KenH RT/10 and GTS Discussions 5 08-12-2005 06:00 AM
Fuel Injector Cleaner NK BREKR SRT10 and SRT10 Coupe Discussions 4 06-08-2005 09:42 AM
Injector connectors SapphireGTS RT/10 and GTS Discussions 13 03-10-2004 04:30 PM
Roe supercharger and injector connectors........pics........... 1TONY1 RT/10 and GTS Discussions 10 08-08-2003 02:38 PM
best fuel injector cleaner? RickV2K RT/10 and GTS Discussions 8 08-09-2001 09:02 AM
