Old 06-26-2008, 03:49 PM   #1
Sean Roe
Site Sponsor
Sean Roe's Avatar
Default 1992-2002 New spin on the old fan Radiator Fan Control Kit… Now fully adjustable!
Hi Everyone,
As some of you may know, we’ve been making the radiator fan control kits for the Viper since my GTS puked coolant in a parking lot after running hard in 1999. That was my first clue that the fan stopped when the engine shut off, which certainly didn’t help with the heat that was soaking into the coolant from the exhaust manifolds and areas around the heads.
Several hundred fan kits later, we’ve made an upgrade to the kit, just in time for the hot summer months.
Our tried and true Radiator Fan Control kit has always featured a heavy duty relay, 12 gauge power wires, 40 amp fuse, high temperature loom, harness lengths built specifically for the model year the kit is going on, all installation connectors and supplies with detailed instructions. The purpose prior was to cycle the fan on and off after the engine was shut off hot so that boiling didn’t occur in the cylinder heads, causing loss of fluid and air pockets in the heads (compounding the temperature problem).
We’ve improved the functionality of the kit, adding the ability to set the fan “on” temperature when the engine is running while retaining the after run cycling to cool the motor. The new system is user / installer set and works extremely well. Installation time is still about 25 to 30 minutes. Once installed, you’ll run the engine until it gets to the temperature you want the fan to come on at and set the switch. We supply a recommended setting based on testing multiple vehicles. The fan will shut off at 12 degrees lower than the activation point. Once the hot engine is shut off, the fan will cycle short periods on and off, allowing the heat transfer to take place that cools the entire engine (not just the radiator or front of the engine).
The new kit is priced at an introductory $89. If you have an older version of the fan kit, you can send it in and we’ll update it with the new components and instructions for $55 (plus S&H as applicable). The kit comes with a 30 day money back satisfaction guarantee and we’ve increased the warranty to one year from date of purchase!.
If you have any questions, please feel free to ask.
We’re actually working on several new products right now.
Here’s a link to our website with the fan kit:
1992-1996 RT/10 only : Dodge Viper Fan Control Kit - 92-96 RT/10 - Cooling - Roe Racing
All 1996-2002 GTS and 1997-2002 RT/10's : Dodge Viper Fan Control Kit - 96-02 Viper - Cooling - Roe Racing
Regards,
Sean
Old 06-27-2008, 05:27 AM   #2
treesnake
Gateway VCA Member
Default Re: 1992-2002 New spin on the old fan Radiator Fan Control Kit… Now fully adjustable!
Sean,
If you have an SCT programmer you wouldn't need this, correct?
treesnake is offline   Reply With Quote
Old 06-27-2008, 06:45 AM   #3
Sean Roe
Site Sponsor
Sean Roe's Avatar
Originally Posted by treesnake View Post
Sean,
With the SCT, we can set the fan activation temperature, but not run the fan after the engine has been shut off.
New! Fully Adjustable Proportional Valve Kit NonABS Dave's Big Brakes New Products, Supplier Specials, and Group Buys 18 03-11-2006 11:22 AM
How Many Spin Outs or other loss of Control ? Turbo63 SRT10 and SRT10 Coupe Discussions 53 01-20-2005 06:47 PM
Nitrous -Wheel Spin Control? Bobpantax Performance Modifications 3 12-09-2001 03:42 PM
1992 to 1996 RT/10 Long Life Silicone Radiator Hoses.. Sean Roe New Products, Supplier Specials, and Group Buys 0 05-20-2001 01:18 PM
1992 -1996 RT/10 Silicone radiator hoses .... Sean Roe Archive Management 0 05-17-2001 11:54 PM
