Old 07-04-2008, 03:15 PM   #1
Sean Roe
Site Sponsor
Sean Roe's Avatar
Default Paxton or Turbo Boosted Progressive Water / Methanol Injection Kits
Hi Everyone,
We’re now making available our “Universal” Water / Methanol Injection kit for use on all Paxton SC or turbo powered Vipers.
We’ve taken our standard Water / Methanol kit (used in Roe Supercharged applications) and made a few controller and wiring changes so those without a VEC could utilize the system.
The universal system is boost activated and progressively controlled based on RPM and engine load. When activated, the air fuel ratio curve follows the same path as before, but with a half point richer air / fuel ratio. This can easily be adjusted up or down to meet your engine’s needs, where you may need it richer or leaner. Adjustment to the air / fuel ratio is made by changing the pump pressure or nozzle size. No special tools or computer programming required.
The combination of the richer AFR and cooler air temperature charge quenches spark knock and can allow you to either add additional boost or increase spark advance, both resulting in more power!
If you don’t plan to increase boost or ignition timing, use the system to compensate for a lean fuel mixture or simply as a safety device / cool air performance enhancer for hot days.
An LED lighted switch and dash mount LED light confirm when the system is powered and activating. The system comes with a one year warranty and includes complete installation instruction.
Here’s a link to our site:
Universal Boost Methanol Injection Kit - Viper - Supercharger - Roe Racing
Feel free to ask any questions you may have.
I hope everyone has a great weekend!
Regards,
Sean
Old 07-29-2008, 01:56 AM   #2
MacManInfi
Default Re: Paxton or Turbo Boosted Progressive Water / Methanol Injection Kits
Quick question, where does the reservoir go? No room under the hood with the Paxton.
MacManInfi is offline   Reply With Quote
Old 07-29-2008, 06:57 AM   #3
Sean Roe
Site Sponsor
Sean Roe's Avatar
In the trunk or rear hatch area. Usually on the right side.
Old 07-29-2008, 01:04 PM   #4
MacManInfi
Genious! Not sure why I didn't think of that. Awesome. Will order shortly.
Old 07-29-2008, 01:14 PM   #5
1BADGTS
Sean i am contimplating a supercharged Srt car as car winter project but my engine builder is flat out against a blower for my intended usage.Question,should the water -methanol system fail in any form where as water is not injected for whatever reason under boost what happens to the engine(esp if said system is used to surpress detonation )Do you have any fail safes ect built in to the system.
1BADGTS is offline   Reply With Quote
Old 08-02-2008, 09:36 AM   #6
Sean Roe
Site Sponsor
Sean Roe's Avatar
No, there's no interaction between the W/M pump control and the PCM.
We currently us an LED that you mount inside the car to show the system as active.
A low level light could be added.
Old 08-02-2008, 12:20 PM   #7
1BADGTS
Is what he is telling me correct though- should a failure occur in the water- meth system under boost the engine is basically toast.
Old 08-02-2008, 02:13 PM   #8
Sean Roe
Site Sponsor
Sean Roe's Avatar
Of the dozens of W/M systems around, the only one I know of that has an input to the PCM from the W/M system is AEM's. Both controllers are made by them, so it's a little easier for them to integrate the two.
Regarding a failure occuring under boost toating an engine, now matter what the vehicle system is that fails, fuel, water / methanol , oil, coolant, whatever, yes, if the guy with his foot to the floor doesn't pay attention to what he hears in the engine or sees on the gauges, yes, engine damage could occur.
Old 08-02-2008, 02:38 PM   #9
RTTTTed
Western Canada VCA Member
RTTTTed's Avatar
Whether te engine gets toasted or not due to w/m system failure (such as forgetting to fill the tank) it would depend on the engine, boost level, timing, fuel, and other system failures such as knock sensors, bypassed safety issues and more.
If the engine is built to the max, then it would 'toast' the engine if any of a dozen systems failed, such as fuel pressure reg., fuel pump, bad gas, perhaps a crank or cam sensor, etc. As Sean said if the driver continues to keep WOT when the engine starts to knock he can destroy the pistons, etc.
If the system is set for an improvement in hp or street driving on pump gas then the engine would start pinging/detonating and the driver could let off the throttle and there should be no damage.
Ted
Old 08-02-2008, 09:29 PM   #10
Bobpantax
FL VCA Member
Bobpantax's Avatar
Hi Sean. Correct me if my recollection is wrong, but a few years ago didn't we briefly discuss the use of the window washer fluid reservoir as one of the choices for the water/meth container? Of course it would create a slight inconvenience by requiring manual application of water with the squeegy for cleaning the window when you stop for gas, but locating it in the reservoir would not add weight since the water/ meth would just replace the window washing fluid which, in some cases, is water/meth - yes?
Also, what would be the advantage, if any, of water/meth for a Gen III with a stock Paxton kit - which inludes an intercooler? Do you have some test results that you can post? What other changes would be required to produce the advantage other than the installation of the kit? Also, how is the kit installed with a Paxton? I am having a little trouble visualizing it. Do you have a drawing or instructions that you can post? Thanks in advance for your answers.
Things go better with boost.
Bobpantax is offline   Reply With Quote
Old 08-03-2008, 04:19 AM   #11
bob, i think it would help from a cooling the charge and intake temps standpoint.... no ?
Old 08-03-2008, 09:06 AM   #12
Bobpantax
FL VCA Member
Bobpantax's Avatar
Hi Plum. I understand that theoretically it should but I do not know whether it has an additive effect with an intercooler. I would also like to know where the spray nozzle goes with the Paxton set up. I would like to know how it integrates with the existing fuel management and other elements of the stock kit. Is additional tuning required? Does the stock ECM with the split second and pressure sensor of the stock Paxton kit have the flexiility to accomodate the water meth system? The bottom line is that I would like to see some data with respect to the installation and performance of Sean's w/m kit on a Gen III with a stock Paxton kit. The data should include efficacy, reliability and durability. It should also include installation instructions. I think that, as someone posted above, there needs to be a safety device regarding flow. Someone could check the tank visually and see that it is full and then experience pump failure or line blockage. If the car has been tuned for extra boost due to the advantage of W/M, and the flow is not there when the driver hits the go pedal, couldn't an adverse engine condition present itself? So, I think, as someone mentioned above, there should be some sort of way to test the flow of the system on start up. Since the kit is aftermarket and, I assume will not come with a warranty with respect to the effect of its failure on the drivetrain, the ability to check the flow on start up is important. Even if the probability of w/m system failure might be low as Sean suggested, the result of a failure, if it did occur, could be expensive. Do you agree? What do you think?
Old 08-03-2008, 03:00 PM   #13
i personally never liked the w/m stuff. but recently someone mentioned to me using it to just cool the intake temps alone. and id guess that using just water would be fine for that. on my DLM intake tubes there is already bungs welded in for this.
the reason i never liked the w/m is, if that little nozzle clogs while under boost (especially at high RPM's) i gotta think you're going to have a pretty good problem on your hands. or if the poly tubing ever comes in contact with an exhaust part or something and melts. id definitely modify it to use some kind of copper or SS tubing.
but i agree, some more data would be helpful
the only thing i can think of as a failsafe is possibly a pressure switch inline somehow ?
Old 08-03-2008, 11:59 PM   #14
RTTTTed
RTTTTed's Avatar
I have the water/methanol in my Viper. The car was set-up with 10# of boost, 9-1 Ross pistons and after tuning the car for pump gas, the w/m was added. This allowed the timing to be pulled back for more power.
Only problem I had with it was right after I bought the car. Attending a Car Show in Kamloops (I got first) I opened my hood and noticed that the driver's side front of the engine was wet. When I picked up the water/meth line I noticed that one end was loose. Yes, bad installation and the pressure pushed the plastic line out of the compression fitting so that the spray was onto the engine, not into the intake tube. I borrowed a wrench and tightend the line. No damage, no problem. Could happen to anyone. Mechanic didn't tighten the fitting enough.
Copper line would be less reliable, in my opinion as it doesn't flex and cracks easily. If it gets hit by road debris it may fail, instead of just bouncing out of shape and returning to normal.
If my tune was set at KILL or max power the engine may have been damaged, but since I drive the car on the highway it's possible that a KILL tune could ruin the engine with 1 bad tank of gas.
If you guys are really worried then maybe you want to use an AEM or Vec3 so that you can change between a KILL tune for the track and a conservative tune for the street? That way the engine would be safe for nearly all systems failures (timing, cam and crank sensors, ECU, fuel pump, etc.) except when using the tune for max hp?
I've read threads on this site that claim 17rwhp because of w/m. Personally, I think 35-50rwhp is reasonable with high boost applications. Huge power and longevity increase for the money. W/m is unnecessary and not an improvement until 8# boost (with the Roe blower) since there is no appreciable temp problem until after 8#.
I recommend it - it's on my car.
Ted
Old 08-05-2008, 05:49 AM   #15
1BADGTS
Thanks guys ,i am considerating a winter project and i am exploring all options regarding my intended use of the Viper.As i said earlyier my engine builder is adament that if i go Supercharger the blower most have the largest possible intercooler (hand fabricated if neccessary)-saw this kit pop up and thought it might or may be a viable alternative ,addition.
Water/Methanol injection check valves KenH RT/10 and GTS Discussions 1 03-05-2007 07:20 AM
Water methanol injection problem Got Venom RT/10 and GTS Discussions 9 08-07-2006 10:02 AM
Water / Methanol injection for naturally aspirated. It works great.... Sean Roe RT/10 and GTS Discussions 7 09-28-2005 09:50 AM
Roe Water Methanol Injection Question. MiamiSpd RT/10 and GTS Discussions 4 08-22-2005 03:34 PM
water methanol injection installed fast? RT/10 and GTS Discussions 29 03-17-2004 06:34 AM
