Go Back   Viper Club of America Discussion Forums > Viper Competition Coupe Discussion > Owners Technical Discussion
Owners Technical Discussion Private forum for Comp Coupe Owners to hold technical discussions
Old 03-19-2004, 11:06 AM   #1
JoeB
Default Rear Brake Calipers
Has anyone had any problems with the rear dust boots? Mine are already brittle and cracked. The fronts are in like new condition. I'm thinking that the rear has no ducting so the heat is not directed away from the pistons, then the dust boots get brittle. If this is the case, I will be adding ducting to the back. Anyone have any input?
Joe B
JoeB is offline   Reply With Quote
Old 03-20-2004, 05:19 PM   #2
DonMc
Default Re: Rear Brake Calipers
replied on general comp coupe forum
DonMc is offline   Reply With Quote
Wanted: right rear brake calipers Tom, F&L GoR RT/10 and GTS Discussions 3 05-02-2005 09:46 PM
40mm rear brake calipers available Tom, F&L GoR Performance Modifications 9 12-14-2004 05:54 PM
Rear Brake calipers JoeB General Viper Competition Coupe Discussion 4 03-31-2004 02:46 PM
One pair of 38mm rear brake calipers available Tom, F&L GoR RT/10 and GTS Discussions 0 12-12-2003 07:13 AM
Rear Brake Calipers V10 MOJO RT/10 and GTS Discussions 6 04-12-2003 08:16 PM
