Old 06-25-2002, 04:50 PM   #1
Gerald
Default Re: Wheel hop cure
Check and mess with tire pressure, with my pressure to low I'll get bad wheel hop also. Put a little air in it and see if that helps...
Gerald
Gerald is offline   Reply With Quote
Old 06-25-2002, 10:00 PM   #2
TOOOFST
New tires,don't power shift.Kuhmo's cure it for sure,mostly its that simple.
TOOOFST is offline   Reply With Quote
Old 06-25-2002, 11:20 PM   #3
davem
Default Wheel hop cure
Hello,
I'm new to the Viper club, bought a 96 GTS last week. I have a small performance shop in Maine where we do dyno tuning and custom turbo installs (http://www.cmperformance.com). We are building our own turbo setup for the Viper this fall - but that is another story.
The car is basically stock, and it has some pretty mean wheel hop in 1st gear when I step on it - Does anyone have a cure for this?
thanks a lot,
Dave.
davem is offline   Reply With Quote
Old 07-08-2002, 10:05 AM   #4
davem
Thanks guys,
The tire pressure was the cure! Great suggestion..
thanks,
Dave
I'm additcted and there is no cure Projecting IMAX 70mm Sneaky Pete's Place 3 03-10-2004 10:09 PM
Crusin for a Cure Greg W VCA Viper Events and Gatherings 3 09-05-2002 09:11 AM
Cruisin' For A Cure ACR Larry RT/10 and GTS Discussions 3 08-13-2001 02:34 PM
