Go Back   Viper Club of America Discussion Forums > General Viper Forums > Performance Modifications
Old 08-21-2005, 04:40 PM   #1
Dave's Big Brakes
VCA Member / Supporting Vendor
Dave's Big Brakes's Avatar
Default Proportional Valve & MasterCylinder Upgrade Gen2
This is for those that want the bigger ABS m/c, along with being able to FULLY adjust the rear brakes(will work really great with TOM's 40mm rear upgrade). This allows either min or max brake pressure to the rears, to make them work even better. Playing with the dist block(removing spring,seal, or whatever) still doesn't give you full control. This setup will,from min to max press.
It will be available with a new ABS M/C, or use your old m/c. It will come with s/s lines, pro valve, a new dist block, and mounting plate(not shown in the following pic's), and will bolt up in the same position as the old hardware.
some pic's
These parts will be listed under New Products and Suppliers Specials, ck there for pricing, and info.
Dave's Big Brakes is offline   Reply With Quote
Brake setup: Adjustable Proportional valve Schulmann RT/10 and GTS Discussions 4 05-19-2007 05:42 PM
Gen3 valve covers on Gen2 VIPER BAZ UK RT/10 and GTS Discussions 6 04-30-2006 10:42 AM
New! Fully Adjustable Proportional Valve Kit NonABS Dave's Big Brakes New Products and Supplier Specials 18 03-11-2006 11:22 AM
New Proportional Valve&Master Cylinder Upgrade NonABS Kit Dave's Big Brakes New Products and Supplier Specials 3 10-01-2005 07:32 PM
New Proportional Valve&Master Cylinder Upgrade NonABS Kit Dave's Big Brakes New Products and Supplier Specials 0 08-21-2005 05:14 PM
