Old 08-23-2005, 06:40 AM   #1
orlandov10
Default My 1/4 mile timeslip
I recently purchased a 97 Viper GTS with 3" exhaust and gears, I'm not sure what gear is in that car but in 4th ( 1:1 ) It would run 42MPH at 2000 rpm as compared to my stock gear'd Viper which runs at 55MPH in 4th att he same RPM. I'm wondering how the gears effect the MPH at the dragstrip. The car ran as follows:
60' 2.057
330 5.520
1/8 8.236
MPH 91.60
1000 10.54
1/4 12.472
MPH 116.86
It was very hot out this day, very humid here in Orlando, Florida.. there was a new GT0 with 400HP running 13.6 @ 102 so I think all of the cars were a little down on power. I was on stock tires and launched very easy at about 1700rpm, I got some wheel hop off the line, also I dropped my tire pressure to 23psi.
orlandov10 is offline   Reply With Quote
Old 08-23-2005, 08:31 AM   #2
Casey
Casey's Avatar
Default Re: My 1/4 mile timeslip
Well, your 60s is about consistent for a Beginner with a Viper. Get that down into the 1.8x and you'll be closer to 12.
Depending on the track conditions, you did OK though.
'97 with the minimal mods you have is good for 12 or less on the right track, right day, good driving!
Casey is offline   Reply With Quote
Old 08-23-2005, 10:11 AM   #3
orlandov10
1.8 on factory tires? How do you suggest launching?
Old 08-24-2005, 10:24 AM   #4
99 R/T 10
99 R/T 10's Avatar
I've done a best of 1.72 on Pilots, JD beat me with a 1.69. Got to feather the throttle and slip the clutch just right
Old 08-24-2005, 07:26 PM   #5
hemibeep
hemibeep's Avatar
As far a the gears, in my roadrunner, I switched from 4.10 to 3.55. It is a torque motor and it allowed the car to "pull" through the motor torque, instead of blasting through the RPM.
Not as sure in a viper, but with the lighter weight and relavtive high TQ, you would be shifting pretty fast. In my mind, with stock tires, it would seem that getting a good 60' would be harder with the taller gear....but I am more knowlegable with older cars and learning the viper.
hemibeep is offline   Reply With Quote
Old 08-27-2005, 11:32 PM   #6
opnwide
S. Texas VCA Member
opnwide's Avatar
So you'd be turning 126 mph at redline....That would put you in the 3.55 range. Measure again at 3000rpms to be sure.
3.55s are great gears for cars with over 500 hp but less than 600. Stock Vipers do well staying with 3.07s and keeping it in 3rd through the lights (117mph rev limiter). On the strip, the extra gear probably won't help your et because of the extra shift. Drag radials may give you a 2/10s advantage over what you're currently doing.
your times are very close to what I run on stock pilots when its about 95 degrees outside.
opnwide is offline   Reply With Quote
Old 08-29-2005, 07:55 PM   #7
2MANYTOYS
Carolinas VCA Member
I turned a 1.56 60' time with your tires in Bowling Green. With the Roe 5 lb pulley. Ran mid 11's
2MANYTOYS is offline   Reply With Quote
pix of my "road warrior" at the strip - timeslip inside Fast Freddy Driven 4 12-23-2006 05:42 PM
10.21 @ 134 mph - pix and timeslip inside Fast Freddy Sneaky Pete's Place 0 12-19-2004 10:55 AM
Finally an 11 second timeslip! CMilViper RT/10 and GTS Discussions 8 03-28-2004 11:50 AM
A Day at the Races (timeslip) Y2K5SRT Archive Management 11 03-24-2001 08:35 PM
Latest Drag Racing Timeslip... FikseGTS Viper Racing/Dyno Results/Time Slips 1 02-01-2001 11:09 PM
