#151 | |
I appreciate your help. I just want to make sure I understand what you did. Thanks. Tom
#152 |
I need help too. same issue.
'06 Red Vert - Bone Stock "making headlines, scaring passengers, and offending decent people on the street"
#153 | |
Florida VCA Member
I suppose as an alternate method you could just back it out until it's flush then wind it in in small increments until the throttle plate doesn't hit any more but I wanted to do a minimum of turning and be able to count total movement .. In all I think I backed it out about 1/4 turn or slightly less but better about 0.019 gap reduction. Judging by the machining on the inside of the TB where it mates to the plate and the coarseness of the set screw, I'd say this could vary quite a bit and that's why you need to do it strictly by feel. Turns aren't a good way to measure this, you need to measure the gap between the link arm tab and the housing right next to the set screw in order to determine how much you've moved it. The set screw will hold the plate slightly open, it will create a gap between the linkage tab and the housing and should, I just reduced the gap slightly which allowed the plate to more fully close so the IAC could control the idle. Most all the idle air needs to be controlled by the PCM via the IAC so the throttle plate should be 99.9% closed. You don't want the plate banging on the housing and you want the throttle arm to hit the hard set screw not the aluminum housing. Your gap values here will vary, I suspect quite a bit. Last edited by fqberful; 01-16-2008 at 09:58 AM. |
#154 | |
it sounds to me as if Nader needs to just back off his stop screw just a 1/10 of turn to the left-(with the battery and ecm disconnected!!) and that will put enough play into the linkage so the TPS can self regulate faster. i have seen where if the throttle cable itself doesnt have enough slack in it this same thing occurs. the linkage is slotted where it bolts to the manifold, so it can be adjusted. you are supposed to have some side to side movement-that is important that it does have some. that is normal Tom, try to turn the stop screw just to the left maybe a 1/10-1/8 of turn to the left (disconnect the ecm and battery first!!) and lets try that. also while you are there feel your throttle cable and see that there is a little play in it. it should not be tight. it should move about 1/2" either direction before any tension is felt when it starts to pull on the linkage or the accelerator pedal. call me after you do this. we will get you dialed in. |
#155 |
I also feel a slight sticking when I press the pedal. must be the blade rubbing.
#156 |
sometimes a simple tap with a plastic screwdriver handle on the linkage will realingn it for you, double check your blade alignment per the instructions. also, just the heat cycles from driving it will usally work it all in. how many miles have do you have so far?
#157 | |
#158 |
X-Metal, I have about 40 miles on it so far.
#159 |
#160 |
i would say looking at the pics you need to slide your cable bracket slighty towards the TB to put some slack into the cable. do that and back the stop screw to the left an 1/8 turn.
disconnect the battery and ecm first. after wards give it 200 miles to adpat. that should fix you right up. |
#161 |
Finally got mine on today.
It's too cold to go out driving but running in the garage, everything seemed fine. Idles right at 800rpm (where it did before) and returns to this level instantly after gunning the engine. Could I be one of the lucky ones? I guess I'll know for sure after driving around. Nevertheless, I didn't get those pretty bolts seen in Nader's picture. I had to reuse the fugly stock ones. BTW - my gap at the stop screw came in at .018 as-is. |
#162 | |
thanks gary 812-477-1740 |
#163 | |
California VCA Member
Dyno results????? |
#164 | |
#165 | |
no 2 dyno runs can be replicated. there are too many variables. you cant compare one best run to another. the most scientific way is run the vehicle 3 times and take an average of those 3 runs, then make your mods, then do 3 more runs. and use that average. there are so many variables that can skew a dyno result; some are the obvious, like air temp and humidity. but there are things that savy dyno operators try to duplicate every time; like strap tension, on the rear of the car can change 5-10 hp, by over tight or too loose rear straps. tire pressure--a big one too, more tire pressure reduces the rolling resistance, and helps show more power. we deflate the tires on a car and refill with nitrogen, as air pressure will change with tire temp changes and nitrogen in a tire will stay the same. your air presure is different after the third dyno run than it was at the first. where the fans are placed, each time. on a single rear drum dyno (most dynojets) where the tire contact patch is located, on the drum.is the car dead nuts centered or forward or back of the center of the drum. is the car completely straight on the drum? another VERY important dyno graph to have your dyno operator pull up for you is an elapsed time run. instead of having the graph read rpm or speed, have him change the dyno to TIME. you may do a mod that doenst make more peak horsepower, BUT it will make more power thru the curve, and that will show the engine reaching its peak power sooner. think of it as 2 cars can both go 150mph and turn 6000 rpms doing it, but the one that reaches that speed first is obviously the fastet and the one that is desired. TIME run graphs on a dyno are VERY important. we had a client who had a cam put in his gen3. it made great rwhp, of 570hp. but it was a dog to drive, so i overlapped his dyno run with a well tuned stock cam engine that only made 500hp. when both runs are viewed on a TIME graph, the 500hp engine made over 140hp more everywhere except at peak power. thats what you want to see, you are only at peak power for an instant, you run thru the curve for the lenght of time you are in each gear. TIME shows how effecient an engine is at making its power. you must always compare apples to apples when doing dyno runs, as a dyno run will only show what your current setup is-on that dyno at that time, you could redyno the exact same car by taking it off the dyno putting it back on and they see a 10hp difference! take very accurate notes, moniter tire pressure, make sure the straps are in the exact same place as before and try to record strap tension, look at your weather data results. ask your dyno tech when the last time his dyno was serviced and or what is the current calibration rate. dynos are great tools, but your butt and a drag strip can be more usefull sometimes. if anyone ever has any tuning questions, please dont hesitate to email or contact me anytime. |
| Throttle body rebuilding....... | IEATVETS | RT/10 and GTS Discussions | 7 | 10-20-2005 06:22 AM |
| New Throttle Body | Volltage | SRT10 and SRT10 Coupe Discussions | 14 | 09-09-2005 10:57 AM |
| RSI Throttle Body | Nich0las | SRT10 and SRT10 Coupe Discussions | 1 | 04-10-2005 08:07 PM |
| SRT Throttle Body Mod | rubbersidedown | Performance Modifications | 10 | 03-09-2005 05:16 PM |
| Throttle body questions... | GTS-R 001 | RT/10 and GTS Discussions | 5 | 09-01-2002 05:24 AM |
