#166 | |
California VCA Member
#167 | |
we might need to get your pcm sent to us, so i can add some more fuel to it, and in turn you will make some more power and torque everywhere. i would need 3 current back to back pulls with AF curves, and we could write a custom program for it, and really wake her up! |
#168 |
I have a few pulls 3 with corsas and my RSI with K&N filters. 3 with DC Performance,pcm adjust w/RSI air and 3 with new Tb and K&N and the Corsa's I will put it together and email them to you. Need and email address Gary.
Thanks Chris |
#169 | |
gary@esuperbike.com |
#170 |
IL VCA Member
has anyone done an independent dyno run with the throttle body?
#171 |
I did a few dyno runs with the new TB but, as Gary noted before these can be very different from run to run. I didn't gain but 1 hp and lost 13lb of torque on the dyno but, again I an not sure if that matters. I get really confused with the whole dyno thing..... If you can't get it dyno tuned by one of the pros its seems really not worth doing.
#172 | |
IL VCA Member
i bought this when it first came out and just had my buddy install it. i havent driven it yet. but losing 13lbs of torque?? if thats indicative of the part, ill just take it off and **** can it. isnt your car a paxton? if so, i would still think if the TB is doing its job u shouldnt lose 13lbs of torque... sheesh...to gain that 13lbs of torque back naturally aspirated will cost thousands... nice. |
#173 |
I didnt notice loss or torque. In fact you will notice a nice increase in throttle response. The change in torque could simply be variation between dyno runs.
#174 |
I agree with you on this and I thought I said that the dyno runs can't tell you all as it has so many vairables. Gary had mentioned this in an earlier post and it made perfect sense. And the on board computer has adaptive issues as well. I am not unhappy with the single blade TB. I just dynoed less with it on. I only dynoed it once. It surely would be different if I did it again. I gave up on the dyno thing unless I get it dyno tuned. since I really don't race the car I begin to think that a lot of this Viper bolt on stuff is just not necessay. I like my corsa, B and M shifter, Ps2 tirew and my gears. I have to realize that the quest for speed is probably in most guys but, more and more it harldy seems worth it. I just like the car.( especially after being stopped by CHP it kinda takes the wind from your sails.) Thanks and be safe...
#175 | |
Hi there I installed this throttle body in my 2004 SRT and it works fine especially above 4500 rpms the engine is more willing, especially in hig altitudes, great part.
#176 |
TX VCA Member
I finally put my unit on and it worked out well. I broke one of the screws but got my brother-in-law who's an accomplished machinist to remove the screw without touching the threads. I finished the install with no issues and the throttle response is very good. I broke the screw because I didn't file it down enough - it was my first one. The install is quite easy if the directions are followed closely.
2005 Commemorative Edition; other hot rod; 2007 Chrys 300C. Two bikes - 97 Harley Superglide & 06 Honda 1KRR. |
| Throttle body rebuilding....... | IEATVETS | RT/10 and GTS Discussions | 7 | 10-20-2005 06:22 AM |
| New Throttle Body | Volltage | SRT10 and SRT10 Coupe Discussions | 14 | 09-09-2005 10:57 AM |
| RSI Throttle Body | Nich0las | SRT10 and SRT10 Coupe Discussions | 1 | 04-10-2005 08:07 PM |
| SRT Throttle Body Mod | rubbersidedown | Performance Modifications | 10 | 03-09-2005 05:16 PM |
| Throttle body questions... | GTS-R 001 | RT/10 and GTS Discussions | 5 | 09-01-2002 05:24 AM |
