Old 02-04-2008, 11:38 AM   #1
Tim
Alberta Canada VCA Member
Default Codes, tuning with Stryker Heads and Cam?
I will go with the Stryker Heads and probably the cam but before I do I have a couple of questions.
My 2002 RT10 is stock except for the 3” Corsa and high flow cats along with the K&N and smooth tubes and the car runs fine but it is slightly slower than my old 1994 with a Stock Arrow Racing Rebuild
Whose headers will work best here? The B&B or the Bellanger? Do I buy 1 ¾” or 1 5/8”?
Has anyone had any problems throwing codes after these heads and or cams were changed.
What do I buy to tune it with after or does the factory unit adjusts sufficiently for the additional airflow?
At the end of the day I don’t; have the time to deal with a bunch of headaches if there are problems in going this way.
I’m up here in Calgary Alberta and we don’t have the resources with experience to chase down any problems. The shop here in Calgary that most of the Viper owners are using as well as the Vette owners, they are very skeptical that I will gain the claimed 100 hp with these mods on a NA cars compared to the supercharged cars that are out there.
Thanks in advance.
Tim
Tim is offline   Reply With Quote
Old 02-04-2008, 03:18 PM   #2
RobZilla
Florida VCA Member
RobZilla's Avatar
Default Re: Codes, tuning with Stryker Heads and Cam?
I'm sure someone with a lot more knowledge will be along soon, but heres my .02 cents. I would suggest at a minimun getting a Vec II or III. When replacing the headers with a 3" exhaust, it's possibly to throw an O2 sensor code. This is a problem that I am working on in another thread.
You wont need anything behind the Cats since you still have em. Some will suggest that after you get everything installed, taking it to a dyno to tune it all in.
I have B&B headers on mine, I love em and the sound is incredible. At idle in gas stations or traffic lights I get tons of comments
'00 Black RT/10 - - B&B Headers, Cat Delete, Corsa CatBack Exhaust, '06 Tranny, K&N,
Smooth Tubes, Poly Mounts, Vec II, HID's, Short Throw Shifter, Chromoly Flywheel
Old 02-06-2008, 10:31 AM   #3
Camfab
Camfab's Avatar
Facts on my car 2000 ACR
Striker + JM cam = 150 rwhp gain
You must tune the car, mine was barely driveable without tune. DC Performance can do that.
10 K+ in parts alone, without headers + tune you'll be closer to 13 K+
If your worried about issues and your not 100% confident of your skills or the shop your going to use, leave the car alone. No need to spend extra cash on a VEC II either.
Old 02-06-2008, 10:49 AM   #4
black mamba1
NY / CT VCA Member
black mamba1's Avatar
You will at minimum need a VEC 3. Or have someone go right into your PCM and change the adaptives to your new conditions. The newer the car it seems the tighter the range the PCM will allow w/out throwing codes. I have a head and cam job and a VEC 3, and am STILL throwing codes, but I have an aggressive tune. I would rather clear the codes than lose power by detuning.
But yes, you will deff throw codes with your mods w/out the VEC or DC tune. Throwing the code will put the car in safe/limp mode and you will lose power, you dont want that!
blk 04 SRT bullet-proof NA motor by Tator, ported heads, comp cam, Belanger exhaust, VEC 3, comp oil pan, roll bar, nav, 08 Lemke hood, 528 rwhp/537 rwtq
Old 02-06-2008, 11:27 AM   #5
Camfab
Camfab's Avatar
He has an '02, all he needs is a DC tune.
Old 02-06-2008, 07:10 PM   #6
black mamba1
NY / CT VCA Member
Oops, I didnt pick up on that, sorry!
Old 02-06-2008, 11:06 PM   #7
ACPERFORMANCE
In my opinion, the best header to yield the most power would be the American Racing Header in either a 1-5/8 stepped to 1-3/4 or a full 1-3/4. No sliptubes, real merge collector, 304ss steel. They are amazing and come complete with high flow cats and pipes.
As far as your tune, it really depends on how big of a cam you install. The lower vacuum of the bigger cam may have an impact because of the varying load values at different vacuum settings.
On Stock cams for your year we have seen as much as 17.8 inches of vacuum at idle. On some of the cams we have installed from Jm we see about 9 inches of vacuum.
The factory computer will learn and help adaptives all around BUT you will definately need some tweaking to perfect driveability and get maximum power. An air fuel curve or dyno printout after installation would really help a tuner make adjustments on your computer in the appropriate places.
As far as engine management, A VEC3 will allow you to tune the car easier in my opinion. If you have a VEC3, an air fuel gauge plumbed in for datalogging, and a computer, you can honestly get some assistance over the phone, and avoid multiple reflashes or driveability issues. and you have all the tuning tools at your disposal.
A computer flash can help but ultimately you are far away without alot of assistance there. May be better for you to have a base tune sent to you with a VEC and then learn to tune it a little with some practice and then you wont need the help that isn't too available to you there.
Just my .02..
If you have any questions, you can always call and ask for me
Todd
A&C Performance
951-816-9111
ACPERFORMANCE is offline   Reply With Quote
Old 02-07-2008, 06:22 PM   #8
Tim
Will I still need a VEC even after sending my PCM away to Dan for tuning? Does anyone know the profile of Jeffs cam?
CamFab, what other stuff you have on your car? What are your final HP and Torq number?
Old 02-09-2008, 10:25 AM   #9
Camfab
Camfab's Avatar
As far as what's done to my car Finally got it tuned @ DC Performance Today . Last time I dyno'd the car it made 585 HP/TQ at the wheels. The American Racing header in the stepped version sounds like the right call to me. I want to try a set of those and campare the results against my smaller SVS headers but I've got to wait this damn writer's strike out.
Old 02-22-2008, 06:44 PM   #10
Tim
To put this togther, who is the best bet to go to to buy all of the gaskets etc from?
Old 02-23-2008, 04:08 AM   #11
tators dodge 914-763-3136
NOT affiliated with any tuner...
Old 02-23-2008, 04:42 AM   #12
SSSSE YA
California VCA Member
SSSSE YA's Avatar
Call Dan @ DC Performance, He is working on my Viper right now with the same problems (codes). I am sure he can anwser all your questions..
DC Performance Stage 6 18/19 HRE 547R,K&N's, Smooth Tubes,Alum.Flywheel,Stryker Heads & Cam package,S.V.S. Shifter with 1 5/8 L.Tube Stepped Headers,Borla Catback,R.T. Metal Cats,MGW Goodies,5Pts,3:55 Gears,Wilwood Big Brake Kit,Thermal Insulation Kit,Eibachs
SSSSE YA is offline   Reply With Quote
Old 02-23-2008, 07:27 AM   #13
Tim
What kind of problem are you having and what codes are you throwing?
Old 02-23-2008, 02:57 PM   #14
SSSSE YA
SSSSE YA's Avatar
Paying my bill @ DC. I really do not know, we are still talking with Dan. I think it is under control now.
Old 02-27-2008, 12:06 PM   #15
vprtech
The Striker head/cam combination is awsome, although it does present some tuning challenges. You could tune the wot afr and timing with the VEC2/3 or other piggyback device, but you will still have drivability issues if you don't recalibrate the pcm. Because of the overlap of that camshaft and the resulting low vacuum and high exhaust dilution, the factory pcm calibration is going to do strange and unpleasant things to way your car drives. Things like surging at cruise and severe idle hang on decel, and will certainly throw dtc's for missfire, O2 sensors, etc no matter how well the car is tuned with a external tuning device such as a split second box or VEC . All of these issues can be corrected with a pcm calibration.
Rob's car was not throwing codes, he was having monitor issue that should now be corrected
- Chris
DC Performance: Proven Performance
vprtech is offline   Reply With Quote
Anyone put Stryker heads on a new Coupe? Viper X SRT10 and SRT10 Coupe Discussions 14 11-01-2007 04:05 AM
Roe s/c: 5psi w/ported heads vs 7 psi w/unported heads FE 065 RT/10 and GTS Discussions 31 06-07-2004 04:43 PM
SVS Stryker TT PaulB RT/10 and GTS Discussions 0 10-01-2001 01:17 PM
Mopar street heads vs. Porting stock heads? LTHL VPR Archive Management 6 03-10-2001 05:02 PM
Mpar street heads vs. porting stock heads? LTHL VPR Performance Modifications 0 03-04-2001 10:48 PM
