Register Blogs FAQ Members List Search Today's Posts Mark Forums Read
04-25-2008, 04:10 PM   #1
countlambo
Default New Mod.
Whats cheapest and best Mod to do to a viper to help proformance
on a viper I know supercharge or turbo is the best but Im just starting out
countlambo is offline Reply With Quote
04-25-2008, 04:38 PM   #2
Hamrhead
WV/PA VCA Member
Hamrhead's Avatar
Default Re: New Mod.
As always, Nitrous.
Though, I want no parts of it.
Mike
'06 Black Coupe
Hamrhead is offline Reply With Quote
04-25-2008, 04:40 PM   #3
BANDIT118TH
Headers and exhaust---no draw back and must be done prior to any induction mod.
BANDIT118TH is offline Reply With Quote
04-25-2008, 04:58 PM   #4
countlambo
what kind of price for headers and exhaust and what is a good brand name for the headers and exhaust and do viper have a computer chip to replace
04-25-2008, 10:00 PM   #5
chimazo
Virginia Maryland VCA Member
chimazo's Avatar
Use the "Search" function and you'll see that, provided you have a '98-02, headers will get you minimal gains for the $1500-2K you'll spend on them. Much better bang for the $$ is hi-flow cats and exhaust.
Wouldn't it be better to wait until you actually have a Viper to modify before getting ahead of yourself with specific mods? You might buy one that already has mods, saving you the trouble.
'98 Viper RT/10, red w/11k miles. JMB intake, hi-flow cats, Borla, SCT tune
'96 Caprice 9C1
'02 Z06 562rwhp/467ft-lbs**SOLD**
chimazo is offline Reply With Quote
04-25-2008, 11:01 PM   #6
RTTTTed
Western Canada VCA Member
RTTTTed's Avatar
Smooth tubes and "Green filters". Probably $200 and 10+hp.
Hi flow cats will reduce the high side sill temps of the stock Catalytic Convertors and add 10-20 hp ($500). If allowed, No cats and oxygen sensor simulators.
For HP, 40% increase with just a used Roe Supercharger. Exhaust helps, but not necessary. Probably a 50% increase in torque starting at 2000rpm! Later, add exhaust, headers, and change pulleys to go to another couple hundred horsepower - if you want it.
Main advantage Roe compared to Paxton is not just the torque, but the ease of installation (6hrs DIY) and upgrading to higher hp. The Roe comes with a Vec 2 and is easily programmed with "smart cards" and has lots of after purchase help from Sean. Water/meth injection should be added after the miniumum boost (depending on pistons).
If you have a Gen 3 you'll have to go to a Paxton since there's no Roe available for them.
Ted
RTTTTed is offline Reply With Quote
04-26-2008, 09:35 AM   #7
countlambo
I no for sure I`m going with a Gen 2 the only reason Im asking is that I want to get right amont of money to do it all at once And think you for your help
04-28-2008, 05:38 PM   #8
99 R/T 10
I have a set of headers I am selling:
ViperAlley Classifieds - 1 3/4" headers TNT - Powered by PhotoPost Classifieds
SAVE TATORS DODGE!!!!!!!!!!!!!!!!!!!!!!!!!!!!
99 R/T 10 is offline Reply With Quote
04-28-2008, 06:03 PM   #9
RTTTTed
RTTTTed's Avatar
The Belangers 5>2>1 are a great design and I like the triple collectors. However the pickles are to maintain velocity at lower rpms and hurt the top end performance.
[img=http://img136.imageshack.us/img136/2724/belangerheaderssp0.jpg]
Removing the pickles opens up the collectors for higher exhaust flow and I took them out of the headers.
In this pick you get an idea of how much restriction the pickles cause.
Hope this helps you guys a little.
Ted
04-28-2008, 06:07 PM   #10
RTTTTed
RTTTTed's Avatar
04-29-2008, 04:01 PM   #11
ViperTony
ViperTony's Avatar
Ted, how did you get the pickles out without butchering the collectors?
WE SAVED TATOR'S DODGE
ViperTony is online now Reply With Quote
04-29-2008, 05:56 PM   #12
RTTTTed
RTTTTed's Avatar
The top pic shows how a couple of the pickles came out when I torched them. The smaller collectors had less room so I had to start torching them from the very top and melt them away. Major PITA. I did ende up using my MIG welder to repair a couple of pin holes though. Not a fun job. Great designed headers. I have always studied exhaust technologies and often made headers and really like the way the Belangers were made. I do feel that they're a superior product. These seem to be 1 5/8" tube or I'd be putting them onto my car. Instead I guess I'll be building 3" collectors for my Edelbrocks.
Ted
04-29-2008, 11:07 PM   #13
PhoenixGTS
Come on guys don't steer the noob wrong - sticky rear tires are by far the most cost effective mod you can do to a Viper.
PhoenixGTS is offline Reply With Quote
05-08-2008, 12:52 AM   #14
Russ M
Learning to drive it.
Will be worth far more than any mod, not to mention will keep you out of guard rails.
Russ M is offline Reply With Quote
vB code is On
Viper Club of America - Archive - Contact Us
