Old 06-23-2008, 08:13 AM   #1
countlambo
Default supercharger vs turbo
Which is better.
countlambo is offline   Reply With Quote
Old 06-23-2008, 08:15 AM   #2
ViperTony
ViperTony's Avatar
Default Re: supercharger vs turbo
This has to be one of the most debated topics here...try using the search feature "Turbo vs. Supercharger", "Roe vs. Paxton" should yield some fruit.
WE SAVED TATOR'S DODGE
Old 06-23-2008, 09:22 AM   #3
Bobpantax
FL VCA Member
Bobpantax's Avatar
As noted above, this is a frequently debated topic. A few comments to help you focus your inquiry:
1. There is a difference depending on whether you are asking about Gen I and II or Gen III. Gen IV cannot be supercharged or turbocharged - yet.
2. The stock Paxton kit for Gen III's, which has a limited three year warranty with an optional drivetrain warranty available, when installed by an experienced person, is bullet proof. To my knowledge, no one is offering a warranty with the installation of a turbo system.
3.The installation of the stock Paxton kit on a Gen III does not require any change to the rest of the engine. All of the turbo applications that I have read about on this site require some engine work, e.g. piston change out, etc. Take a look at Heffner's website to give you an idea of the work involved and the cost of a quality turbo installation. It is far more dollars than the installation of a stock Paxton kit.
4. Beyond about 750 flywheel HP, without some suspension mods and drag radials, traction becomes more than a little bit of a problem.
5. If you are looking at systems for a Gen I or II, you also have to evaluate the Roe supercharger. It's a twin screw instead of a centrifugal supercharger like the Paxton and it produces power starting at about 1800 RPM. There are threads and many posts discussing the pros and cons of this system.
Good luck. You have alot of homework to do.
Things go better with boost.
Bobpantax is online now   Reply With Quote
Old 06-23-2008, 11:26 AM   #4
countlambo
Well I have a gen II just looking for the most power you can get under $10,000 and that I can do myself
Old 06-23-2008, 12:11 PM   #5
Billy Coons
Virginia Maryland VCA Member
Billy Coons's Avatar
Boost is boost, whether S/C'd or Turbocharged. There are a plethora of ways to make them more efficient and safer to run more boost and fuel(cooling the intake air, ignition & computer changes, etc) but still, you can still only stuff so much boost without upgrading parts in your motor. Boils down to expense, warranty, looks, and what your intentions are. S/C's are cheaper and easier to install. Turbos can run more efficient since it's driven by exhaust vice a belt. ROE has more power off the line, Paxton has more power top end (without upgrading those systems). I have a Paxton on my Gen III and love it. Still needs a bit more tuning down low, but the cost of it, install and tuning put me right at your budget.
Paxton, RT Cats, Corsa, Visco-Loc, 3.55's, DC tune, ZXP3's, rotors, 08 hood & lip splr - to JonB, DC Perf, & Dyno-Tuned Perf (VA)!
N/A: 464rwhp & 501rwtrq; S/C: 600rwhp & 530rwtrq
Billy Coons is offline   Reply With Quote
Old 06-23-2008, 12:20 PM   #6
countlambo
Thanks for your input
Old 06-23-2008, 02:42 PM   #7
PJJP
TX VCA Member
PJJP's Avatar
Location: See avatar above because you will not be able to read my plate from your distance behind me.
UGR give 24months warranty on turbo builds
'06 Red Vert - Bone Stock "making headlines, scaring passengers, and offending decent people on the street"
PJJP is offline   Reply With Quote
Old 06-23-2008, 04:08 PM   #8
easy way to put it, if you can afford the TT, do it.
Old 06-23-2008, 05:40 PM   #9
jamie furman
jamie furman's Avatar
Turbo has to be the best as it is less temperature sensitive and it doesn't take HP to work and a supercharger uses a significant amount of HP from the engine to power itself.
jamie furman
jamie furman is offline   Reply With Quote
Old 06-23-2008, 07:19 PM   #10
DAMN YANKEE
New York/Conn VCA Member
DAMN YANKEE's Avatar
Roe, do it yourself, enjoy the ride...
Old 06-24-2008, 06:40 AM   #11
FATHERFORD
FATHERFORD's Avatar
plain and simple
Old 06-24-2008, 09:33 AM   #12
countlambo
Is there a web site that I can go to where you bought your TT at
Old 06-24-2008, 09:34 AM   #13
countlambo
Haven`t seen what the TT looks like under the hood but your supercharger looks great
Old 06-25-2008, 03:41 PM   #14
DAMN YANKEE
It looks exactly like this minus any additional performance work that looks at all good. :>
Here is how simple a 1,000hp supercharger can be..
Keep it simple, go fast...go Roe.
Click on the photo...
Old 06-25-2008, 05:26 PM   #15
Red Snake
Gateway VCA Member
Red Snake's Avatar
That's wicked man!!
Looks like he needs to tighten the belt on that puppy though.
97 GTS Red/Black Stripes - Roe S/C
"That's not the tires squeeling, that's the asphalt beggin' for mercy!"
De Oppresso Liber
Red Snake is offline   Reply With Quote
« Toyo tires F/S | - »
FOR THOSE OF YOU THAT NEVER SAW A TWIN TURBO AND SUPERCHARGER IN ONE CAR! VIPER D Driven 18 06-21-2006 09:59 PM
Heffner Twin Turbo vs Supercharger Real Hummer RT/10 and GTS Discussions 28 01-16-2006 04:35 PM
Turbo/supercharger systems GTS Bruce RT/10 and GTS Discussions 10 06-19-2005 07:11 PM
What do you think of this concept??? Twin Turbo/Supercharger utahviper RT/10 and GTS Discussions 0 04-01-2003 11:42 AM
Turbo or Supercharger? Chuck 98 RT/10 Performance Modifications 23 02-07-2002 07:06 PM
