Gen 4 & 5 Straight Line Performance from late 90s Viper without idle quality loss.
ericj96
Atlanta Georgia
I have been through a series of mods to my 1996 RT10 and would like to share some technical observations that may be helpful to those that would like to bring their late 90s Vipers up to gen 4-gen 5 straight line performance standards without sacrificing the cars drivability and idle characteristics. In short those that want their great looking collectable car to run like a gen four or gen five and almost pass for stock.
Heads:
Below is the dyno result from the installation of a set of Greg Good heads with roller rockers. The valves are 2.02/1.58 with 69.5 cc chambers after being milled. This yielded about a 10.2 to one mechanical compression ratio on my gen one.
Mod Set 1=Smooth Tubes & Filters, 3" borla exhaust from the manifold flange back
Mod Set 2= Smooth Tubes & Filters, 3" Borla exhaust from the manifold flange back, with Greg Good Heads and 1.7 Harland Sharp Rockers
Both data sets have stock throttle bodies, intake, cam and exhaust manifolds.
..........MOD1....MOD2
RPM T....HP.. ...T.....HP
1600 ................423 129
1800 ................424 145
2000 406 155 ..425 162
2200 412 173.. 424 178
2400 410 187.. 422 193
2600 417 206.. 441 218
2800 420 224.. 450 240
3000 420 240.. 452 258
3200 432 263.. 461 281
3400 442 286.. 479 310
3600 461 316.. 492 337
3800 460 333.. 491 355
4000 455 347.. 495 377
4200 455 364.. 502 401
4400 451 378.. 495 415
4600 438 384.. 490 429
4800 433 396.. 485 443
5000 420 401.. 469 446
5200 401 397.. 451 447
5400 383 394.. 439 451
5600 365 389.. 418 446
5800 335 370.. 390 431
6000 ................360 411
The entire torque curve lifted at least 12 ft pounds from 1500 rpm all the way out. Average increase in rotational force was about 9% at all points. Peak RW torque was up 40 ft lbs and peak horse power was up 50 RWHP. Peak HP and torque moved up 400 RPM. The heads flowed 285 cfm at 575 lift and 225 at 550 lift respectively. Point being have Greg Good rework your heads.
Picking the right cam:
I see it over and over on the net. People recommending these massive cams in our cars and then I go over and look at our long narrow runner manifold that wants to go completely out of resonance by 5750 RPM? There is an old adage in engine building that says “help your engine do what it wants to do and it will love you for it”. These massive long stroke engines with long runners want to build lots of mid range torque first and foremost. You can force the motor to peak in the 5500-6200 RPM range but you don’t pick much NET area under the curve for your efforts.
When I went to pick my cam I needed to know what was typical of the late 90s viper engines so I sent off some material to Comp Cams to be “cam doctored” these were the results:
Stock Gen I Viper Cam
Duration at .006” lift intake = 285 deg
Duration at .006” lift exhaust = 278 deg
Duration at .050” intake = 218 deg
Duration at .050” exhaust = 212 deg
Intake Center line = 117 deg
Angle between lobes = 114 deg
Intake lift at lobe = .308
Exhaust lift at lobe= .291
Intake closing event was 77 deg after bottom dead center----translates these cams do not have the exact same lift and close rates on the lobe if what comp cams is reading is correct.
708 Gen II Cam 1996 to 1999
Duration at .006” lift intake = 288 deg
Duration at .006” lift exhaust = 296 deg
Duration at .050” intake = 220 deg
Duration at .050” exhaust = 230 deg
Intake lift at lobe = .321
Exhaust lift at lobe= .321
It has been my experience that on fixed timing (non direct injection) engines running pump gas you are asking for predetination problems when your cranking cylinder pressure gets into the 190s. Most tuners and the new Gen 4 and later engines are running without issue 10.2 to one compression so that’s the ratio I picked. The next question was what is the ideal intake valve closing point on the cam to give me my target cranking cylinder pressure of 182? The cranking pressure models suggest that 74 degrees after bottom dead center will yield a 182 psi cranking cylinder pressure.
Note that both the above listed factory cams have an intake duration of about 220 deg at .050” lift and a 117 intake center line. This late lobe center is the child of the long runners and the need for late valve closing as the column of incoming air is still trying to get into the cylinder long after the piston is on its way back up. This is black magic got to test it to get it right kind of research so I left the cam lobe centers in the same location Dodge did in the 90s before lobe centers were moved to keep the tree huggers happy in 2000.
Based on this I went looking for intake lobes and found the following:
Comp Cams Dodge Viper Camshaft Single pattern with 3051 lobes:
Duration at .006” lift intake = 274 deg
Duration at .200” intake = 134 deg
Intake lift at lobe = .320
Intake closing event was 74 deg after bottom dead center
This is a faster than stock acting lobe that was developed for offshore marine racing engines that need to survive endless duty at high RPM and have excellent longevity characteristics. This cam has more area under the lift curve than the 708 but gave me a much higher average cranking cylinder pressure ranging from 181 to 189 psig depending on the cylinder bank and razor sharp throttle response. The engine now produces 550 RWT and I attribute some of this to increased area under the curve and high cylinder pressure created by a close to ideal intake valve closing point for the application.
I was so paranoid about losing my stock idle characteristics I just went with the same exhaust lobe as I did on the intake on a 114 lobe center angle. This profile made a wonderful gen one improvement cam. Its total specs are listed below.
Duration at .006” lift exhaust = 274 deg
Duration at .050” exhaust = 220 deg
Exhaust lift at lobe= .320
Intake closing event was 74 deg after bottom dead center.
With the new 220 220 114 gen one replacement cam, Greg Good Heads, Harland Sharp Roller Rockers, 1.75 Tri Y headers, 3” Borla exhaust (bullet mufflers in the place of cats), 65mm throttle bodies, aluminum flywheel and ASP under drive pulley the car pulls the following rear wheel numbers on the Dynojet on a routine basis. The blue line on the bottom graph is a stone cold motor
and is not realistic or typical.
RPM…….. T....HP..
1600… 430…130
1800… 435…150
2000… 440…167
2200… 440…184
2400… 465…212
2600… 470…232
2800… 465…247
3000… 485…277
3200… 490…298
3400… 505…326
3600… 530…363
3800… 533…385
4000… 545…415
4200… 551…440
4400… 545…456
4600… 540…472
4800… 525…480
5000… 510…485
5200… 495…490
5400… 475…489
5600… 450…480
5800… 430…470
6000… 395…450
When the car pulled through tech at Atlanta Dragway or Atlanta Motor Speedway for Friday Night Drags the tech guys assumed it was a stock mid 90s viper with exhaust work. In the fall and spring with 600-700 DA a off idle launch and no burn out it turns the following if I don’t spin the tires, bog or miss a gear:
Eight Mile
60 ft…..1.85
330 ft… 4.94
1/8[SUP]th[/SUP]…. 7.45 at 99 mph
Quarter Mile
60 ft …..1.84
330 ft….4.92
1/8[SUP]th[/SUP]…..7.47 at 98 mph
1000….9.64
1/4[SUP]th[/SUP]….11.50 at 123 mph
This car runs with cars pulling better RWHP numbers because for a mild NA car its midrange is crushing. There is no “recovering from an up shift”.
If I had a gen two motor and wanted to mimic and replace the 708 but with more rotational force everywhere I would have used the same intake lobe but with the Comp Cam Magnum Marine exhaust lobe 3052 with the following specs:
Comp Cams Dodge Viper Camshaft Dual pattern with 3051/3052 lobes:
Duration at .006” lift exhaust = 284 deg
Duration at .200" intake =134 deg
Duration at .200" exhaust =142 deg
If you have not purchased a Viper Yet but are thinking about an early model I would keep in mind that 1996 was the first year of the easy to program OBD2 computer. I would also consider that 1999 was the last year for forged motors with a PCM that did not process any data from the second set of oxygen sensors. Do NOT use cheap Federal Mogul or Speed Pro roller lifters as you may have the chance to replace them twice because they would not pump up. ;-(
Hope some of this helps someone
Dan Cragin
LA, CA
Re: Gen 4 & 5 Straight Line Performance from late 90s Viper without idle quality loss
Great Info Eric,
We always change to the later Gen 2 injectors and change the calibration for this combination on Gen 1's. Have you done this?
Gen 1 cars can perform like 4-5 cars at the dragstrip!
E
ericj96
Atlanta Georgia
Great Info Eric,
Yes I have stock gen 2 injectors and SCT tune to get my air fuel in line. Thank you so much Dan for your comment because I value your opinion and follow your work.
Eric Jordan
Viper123456
