Hey gang,
My gas cap has the clearcoat lifting in a few spots that no one would notice other than myself every time I put gas in the car. That said, noticing the pitting 5-8 times per week is bothering me!haha..... I have a contact in the motorcycle business that polishes up parts to high polish sheen (using Jewelers Rouge on a buffing wheel?). He states it will appear like chrome after he is done. Of course the clearcoat would be gone, therefore a touch of "autosol" a few times a season is all that is needed to keep it looking 100% I am told. Anyone have any info to share on that? Worse case if it becomes a botched piece I could go with an assembly from MGW is my theory! Thanks for any insight.... |
The problem is the latch area, due to the wear and the removal of the clearcote the corrosion will continue to be a problem. The trick is not the buffing/polishing, the trick is to keep the problem from happening again. MGW does it right, there is no wear area on the latch and everything is tiple plated chrome.
I stripped the clearcoat off mine. Polished it to the look I wanted, grabbed a spraycan with clearcoat and applied it!
Just a couple of hours work and it looks perfect! Mikael ![]() ![]() ![]() |
The early cars did indeed have the corrosion mentioned above. Never cars have a plastic "roller" thingie instead of the metal one. If you are concerned about originality, a new one will be slightly different. Also, you may try your dealer and your warranty. If memory serves me, the cap is covered under the 7 year corrosion warranty.
GO for the MGW gas cap - the stock gas cap is a piece of ****.
![]() ![]() ![]() Since I went for the MGW gas cap I have a brand new stock gas cap available (warranty replacement/never used). Anybody interested - send a private e-mail, please. http://ourworld.compuserve.com/homepages/r_s/viper.htm <FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by MarkusReinhardt on 04-15-2002 at 10:34 AM</font> |
Thanks for the tip Matt, never thought of the corrosion angle, shall try that right away, if no luck I'll continue from there!
| Is there a clearcoat on polished '97 OEM wheel? | Flash Gordon | RT/10 and GTS Discussions | 5 | 06-26-2006 10:53 AM |
| Polish aluminum....where to get the polish | ab | RT/10 and GTS Discussions | 5 | 07-24-2004 03:19 PM |
| Egged - Clearcoat Damage | Rich01RT10 | RT/10 and GTS Discussions | 11 | 03-17-2003 06:13 PM |
| 2001 rt/10 clearcoat is still soft | Vic | RT/10 and GTS Discussions | 3 | 01-31-2002 03:36 PM |
| How much clearcoat is on a late........ | RT/10 and GTS Discussions | 10 | 12-31-1969 06:00 PM | |
