Old 11-21-2001, 08:55 AM   #1
Frank Parise
Frank Parise's Avatar
Default Re: Viper Front->Rear Weight ratio, lbs/in rear tire traction, etc
With full fuel and driver, expect the rear to be about 52% of the total weight (3,600 pounds). Under hard braking, substantial weight transfers off the rear tires and onto the front. I doubt you will ever achieve more than about 1 g in braking force, which will result in weight transfer of about 600 pounds in total. At this point, you will only have 35% of the car's weight on the rear tires. If you are simultaneously trying to turn the car sharply, there's a good chance that the rear will spin out on you. This would be true for any car.
The stock rear wheels are 13" and the fronts are 10" wide.
Frank Parise is offline   Reply With Quote
19" front and 19" rear tire recomendations KepRght Tire , Wheel, Brake and Suspension 3 10-25-2006 11:52 AM
front to rear weight ratio 94RT10VIPER RT/10 and GTS Discussions 4 06-20-2006 05:43 PM
HELP! NEED REAR TIRE IN FRONT ROYAL, VA '00 ACR George Murray RT/10 and GTS Discussions 6 09-09-2004 03:36 PM
HELP! NEED REAR TIRE IN FRONT ROYAL, VA FOR '00 ACR George Murray SRT10 and SRT10 Coupe Discussions 1 09-07-2004 08:01 AM
What is the front vs. rear tire wear ratio? Nadine UK GTS Archive Management 2 11-16-2000 08:08 AM
