Old 04-23-2002, 02:01 AM   #1
Tomer
Default I want the Air Box Engineer-arghhh!!!
OK, I installed my Snake Oyl smooooth tubes and K&Ns tonight.
What should have been 30-40 minutes of joy turned into >60 minutes of frustration...I am still not sure I should drive my snake!!! (96 RT)
First off, the Snake Oyl tubes don't have a visible cut (angle) on one end of the tubes, but they fit OK...The instructions were pathetic, although I know this should be an easy job...
The BIG problem is the STUPID clips on the air box. I found I had to remove the air box to even come close to installing my K&Ns...I noticed I was missing at least one clip when I removed it...Now with the K&Ns, I had those STUPID clips jumping off the air box like gr****oppers...I would install the clip, then clamp it down, then a second or two later, BING, away it goes a good 4-5 feet....Whats with this...Its soooo frustrating!!!!
Are there longer clips available? I believe the issue is in the difference in density (compressability) between the rubber gasket on the stock air filters and the K&Ns...Also, the air box seems a little warped, and combine the two and those stupid clips (did I mention I hate them) just FLY off....
So now, on the driver's side I have 3 of 4 clips, and on the passenger side i have only TWO clips installed...
I am afraid with normal driving and bumps in the road, these stupid (there I go again) clips will fly off...
Help!!
Tomer
(trying to calm down...I hate it when the simplest things get you down....)
PS I don't have any more clips...Boy do I need clips!!
Tomer is offline   Reply With Quote
Old 04-23-2002, 02:13 AM   #2
Tomer
Default Re: I want the Air Box Engineer-arghhh!!!
Oh yah, as of tonight my car it topless, and with the weather being great here I just HAVE to take her to work...But I am worried about the pass side air filter where I only have 2 clips installed...
Tomer
PS Don't get me going on those clips again!!!
Old 04-23-2002, 02:49 AM   #3
Ulysses
Tomer,
Don't drive with it that way. All of the earlier Vipers needed to have a part of the airbox modified (read grinded down) to get K&N's to fit or the clips would pop off.
May not apply to you, though, since you have a '96. Don't know, maybe someone wiser will speak up here.
READ ALL ABOUT IT HERE
Old 04-23-2002, 06:47 AM   #4
Dixter
Check this out.... it may help you even if the years don't match.
Could be an easy fix for you
http://www.viperclub.org/menus/index_how_illup.htm
Dixter is offline   Reply With Quote
Dodge Viper Slammed by Gen-Y & DC Engineer! YellowSnake RT/10 and GTS Discussions 37 09-20-2007 09:34 AM
SRT engineer Charger chat session 8/16 SRT10 Driven 0 08-15-2006 05:39 PM
Want to talk to an SRT engineer ??? 1TONY1 SRT10 and SRT10 Coupe Discussions 10 10-28-2005 09:36 AM
Vette engineer on the Viper viking SRT10 and SRT10 Coupe Discussions 39 09-03-2005 06:32 PM
I got nabbed!!! ARGHHH!!! viperct2001 RT/10 and GTS Discussions 25 05-10-2003 11:50 AM
