Old 06-04-2002, 02:20 PM   #1
toddt
NorCal VCA Member
Default So what happens if I put all these mopar performance parts on my car?
Okay, I know, stupid question, but I'm gonna ask it anyhow.
http://www.mopar.com/m_perf_parts_pr...tegoryID=10026
Will I still be smog legal?
How much horsepower will I have?
Who has most of this stuff in their motor?
toddt is offline   Reply With Quote
Old 06-05-2002, 08:48 AM   #2
toddt
NorCal VCA Member
Default Re: So what happens if I put all these mopar performance parts on my car?
Thanks for the response--I'm more worried more about ACTUAL sniffer output than abiding by some silly CARB rule. I actually do not want to be any more of a polluter than I already am. I think the smog check is the right way to determine if something should be legal or not. If your smog gets worse, it should probably not be--if it's better or unchanged, go ahead!
Mopar parts that make the burn cycle more efficient (and thus make more power) I wouldn't mind considering. No smog center is going to take of my valve cover or check my porting job, so I don't think that's an issue. A big-ugly-cam that spits out half the fuel in the exhaust I'm not interested in.
Old 06-08-2002, 05:44 PM   #3
Todd Richmond
Your car should pass a sniffer test. I just smogged my modified GTS(see sig) yesterday and it passed with below average #s (plenty of room to spare). As long as you have decent cats (mine are unknown high-flow model) and the car runs smoothly, most mods won't make a difference. My old 450 HP Supra Turbo never had a problem either.
My method to help pass is to take it to a local gas station and camp out near the car for the entire check(no test drive required). At $34 including the CA documentation, they don't make much money and therefore don't spend a ream of time trying to nitpick, nor do they have the money for the most extensive equipment, maintainance and training. The other advantage is that you can call ahead and have it done within a few hours, not days.
If you live in an area where they do smog tests on a dyno (not sure if that was ever implemented), mods might be more of an issue. My dad is a mechanic and smog teacher and he said CA's proposal a while back to mandate smog tests through a state-run center on a dyno hit such loud protests (hello!) that they scrapped the plan indefinitely.
Todd Richmond is offline   Reply With Quote
Old 06-08-2002, 07:30 PM   #4
Mike Brunton
Todd,
I'm in a long-winded mood tonight - hope you don't mind my blabbing!
Are you considering all those parts? I'll address a few on your list. As a general rule however, I am very VERY leery of the claim that performance parts are "making your burn more efficient and therefore getting you a cleaner burning car". My experience has shown this is NOT the case. The overall efficiency of a 4-stroke engine is not all that bad to begin with, and most performance parts do not increase it, they simply allow for more flow (meaning more gas and air, and hence a "bigger bang").
Having said that, most parts will not cause you to fail a sniffer test, and if you did, just get some test pipes and throw an extra set of cats on it or play with timing, or put some of that xylene stuff in the gas - there are a million ways to get around the test, in other words.
Ok, onto the list!
180deg. Thermostat: Mostly useless. The Viper reaches equilibrium above the stock thermostat temperature, so if you are running over, say 195 degress, a 180 degree t-stat won't help unless you increase the cooling ability of the system - like with a different radiator, fans, pump, etc. A 180deg stat will only get you to 180 on the highway on a very cool day. For overall better cooling, you really need to upgrade the system, not change the t-stat.
Billet pulleys. I would not run these. I've seen one Viper with pulleys and the headlights dimmed at idle. At higher speeds, you're certainly OK, but at idle you might be a tad low on ampherage from the alternator. These make a minute difference - not enough to make up for the hassle, IMO.
Plug wires and plugs: Don't get alot of gain over stock items, just be sure your stock items are in good shape!
The internal engine stuff... yes, Yes, YES! This is where the power is at. Smooth tubes and filters are first. Then comes a 3" cat back. Then go with headers. This will get you to the 450RWHP mark pretty consistently, if not quite a bit higher. Beyond this, rockers are good, but get the good ones (T&D), these can give you 10-15HP with the aforementioned mods. Beyond that, you need to decide between 1 of 3 paths. Naturally aspirated (heads/cam or a stroker), forced induction (turbo or supercharger), or nitrous. If you want to go the first way, I would go with heads and a cam, or if you want more power, a stroker. I'd personally go heads and cam.
There are several people on this board who do headwork. Maybe Treynor, Venom Lover, and Fred Kinder could chime in - all have or are getting head work. Seems the BTR heads are quite good, and of course Caldwell are excellent (they make the GTS/R motors), and TNT are very well respected too. A non-stroked heads/cam car with the aforementioned mods can easily hit the >500RWHP range and often quite a bit more. Along the way you might want to look at halfshafts if you intend to use this power.
Mike Brunton is offline   Reply With Quote
Old 06-09-2002, 03:55 PM   #5
toddt
NorCal VCA Member
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Mike Brunton:
There are several people on this board who do headwork. Maybe Treynor, Venom Lover, and Fred Kinder could chime in - all have or are getting head work. Seems the BTR heads are quite good, and of course Caldwell are excellent (they make the GTS/R motors), and TNT are very well respected too. A non-stroked heads/cam car with the aforementioned mods can easily hit the &gt;500RWHP range and often quite a bit more. Along the way you might want to look at halfshafts if you intend to use this power.
<HR></BLOCKQUOTE>
Mike--
Another fine post from the keyboard of Mbrunton..
I'll pass on the smooth tubes and filters
I really like the idea of going through the engine and optimizing the innards. I'm a big fan of normal aspiration with some redline margin. I love strong engines that last! (It's why I bought a viper)
Thank you so much for the advice...I'll consider each point carefully when it comes time to depart from stock (if!).
2008 Mopar Performance Parts rcl4668 SRT Engineering Q/A Area 3 03-03-2008 08:44 AM
Mopar Performance Parts for SRT's? Viper Specialty SRT10 and SRT10 Coupe Discussions 4 04-09-2004 09:33 AM
Mopar Performance Parts for SRT-10's Viper Wizard SRT10 and SRT10 Coupe Discussions 44 03-01-2004 10:57 PM
Roe Racing is now an Authorized Mopar Performance Parts Distributor... Sean Roe New Products, Supplier Specials, and Group Buys 11 10-29-2003 10:53 AM
MOPAR Performance Parts = BOGUS! GTS Dean Performance Modifications 2 02-23-2001 11:36 PM
