Old 06-25-2002, 08:49 PM   #1
Diablo Joe
Default Hot side sills
Ive switched to high flow cats,wrapped the cats with header wrap,and painted the inside of the foil cover with black header paint and my side sills are still hot.Any suggestions beside hacking off the cats?
Joe
edit-Ive also installed the side sill vents in the rear.
Diablo Joe is offline   Reply With Quote
Old 06-25-2002, 09:33 PM   #2
Diablo Joe
Default Re: Hot side sills
If I put my hand where the cat is located after spirited driving I can only hold it there a few seconds.Anywhere else is fine.
Joe
Old 06-25-2002, 10:28 PM   #3
GTS Bruce
GTS Bruce's Avatar
Get rid of the cats.My car running without cats is as significant to the atmosphere as me taking a leak in lake Erie. Bruce
Old 06-25-2002, 10:41 PM   #4
Ron
Ron's Avatar
<FONT face="Comic Sans MS">I would think a reflective paint would work better than a black paint. Additionally, the VHT paint should be used underneath the side sill insulation, not over it.
Lastly, I've always been told not to wrap the cats. Could overheat them and perhaps cause a fire.
I'd measure the actual sill temps and compare to a stock Viper to see if you're making progress. Then find out at what temp the exterior side sill paint becomes damaged. If you have a decent variance, no worries.</FONT f>
Old 06-25-2002, 10:45 PM   #5
Ulysses
What brand hi-flow cat did you go with and what size?
Old 06-26-2002, 04:34 AM   #6
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by GTS Bruce:
<HR></BLOCKQUOTE>
Good point Bruce. Where do people think it all goes anyway?
Old 06-26-2002, 05:00 AM   #7
MadMaxx
Gut the cat or remove it.
Are you running rich? when I was having trouble with my plugs, the passenger bank was running SUPER HOT due to the unburnt fuel clogging the cat and exploding.
James
MadMaxx is offline   Reply With Quote
Old 06-26-2002, 05:54 AM   #8
Diablo Joe
James,
Thats what I was thinking but I just replaced plugs and wires and the car "seems" O.K.
Ulysses,
The cats are the Sean Roe Hi Flows.I can tell they are flowing well because I can feel the exhaust hit my leg from 3 feet away from the tailpipe at idle.Where can I get something to measure the temp?
Joe
Old 06-26-2002, 06:12 AM   #9
MadMaxx
I'd still say your running rich... how old are the o2s? I need to replace mine soon
James
Old 06-26-2002, 06:18 AM   #10
pauls
O2 sensors need replaced? If they don't throw a trouble light why would they need changed?
pauls is offline   Reply With Quote
Old 06-26-2002, 04:26 PM   #11
Diablo Joe
I have a VEC controller so Ill lean it out a bit tonight and see what happens.
Joe
Old 06-26-2002, 04:38 PM   #12
grayman
I agree. Cut out the cats and get rear O2 sensors. My 00 GTS side sills run ambient temp, sounds great, no problems.
grayman is offline   Reply With Quote
Old 06-26-2002, 04:49 PM   #13
Ron
Ron's Avatar
<FONT face="Comic Sans MS">Many digital multimeters have optional temp probe.
Also, for less than $100 you can get an infrared non-contact temp sensor. Any HVAC dealer would have it.</FONT f>
Old 06-26-2002, 05:39 PM   #14
silverviper
I'm just curious how well (or if) you pass smog tests without cats? Or is this just a concern in CA?
silverviper is offline   Reply With Quote
Old 06-26-2002, 06:48 PM   #15
ggc
GTS Bruce: No wonder Lake Erie has taken on a yellow tint.
SilverViper: I can tell you from experience that if your area requires emissions checks, you will likely not pass HC. I tried everything, but could not pass until I put cats back on. I used Random Tech high flow cats from Parts Rack and I passed with flying colors. The sills are a bit hotter than they were with no cats, but I had no choice. I can hold my hand on the sills as long as I want. Sounded better with no cats and my headers liked it better too.
ggc is offline   Reply With Quote
Gen 1 side sills Supercharged Vipermad RT/10 and GTS Discussions 2 06-03-2002 07:43 PM
Side sills Forged Horsemen RT/10 and GTS Discussions 8 02-11-2002 09:13 PM
Will Gen II side sills fit on a Gen I. tradin1 RT/10 and GTS Discussions 8 02-01-2002 05:08 PM
Side Sills for a 97 GTS John Stuttle Archive Management 0 05-18-2001 06:23 PM
Side Sills Marc Lublin Performance Modifications 0 11-27-2000 08:09 PM
