Old 03-18-2003, 09:53 AM   #1
Toby
Default Normal operating temp question.
I just want to make sure my 96 GTS is in the acceptable range.
The gauge fluctuates from the first mark past the 190 and goes up about an 3/16 inch or so and then comes back down when the fan kicks on. This is in about 70 Deg air. I am guessing it ranges between 200 and 210?
My 400 HP small block Chevy in my 69 Camaro runs much cooler so I was wondering if this is normal operating temp.
Toby is offline   Reply With Quote
Old 03-18-2003, 10:03 AM   #2
ledfoot
Default Re: Normal operating temp question.
My gauge hangs out at the third middle center line.and creeps a little more in stop n go...sounds about like yours.I have to keep an eye on mine ,because of the dreaded 01 waterpump issue...
ledfoot is offline   Reply With Quote
Old 03-18-2003, 11:16 AM   #3
SteveT
Your temp range seems to be normal.
When I had my first GTS (97 model), it took me a while to realize that the thing was not going to overheat. Seems like the gauge moves around more than any other car I have owned.
SteveT is offline   Reply With Quote
Old 03-18-2003, 07:56 PM   #4
onerareviper
Perfectly normal....
Old 03-18-2003, 08:21 PM   #5
C O D Y
Oregon VCA President
C O D Y's Avatar
Yep... Normal.
C O D Y is offline   Reply With Quote
Old 03-18-2003, 08:33 PM   #6
Marv S
VCA Western Zone Director
that is normal in city driving
It's not normal for highway driving. if you're cruisin at 80 in 5th or 6th gear the needle shouldn't move very much.
Marv S is offline   Reply With Quote
Old 03-18-2003, 08:39 PM   #7
Birvini
Normal.
Birvini is offline   Reply With Quote
I need to know normal engine temp on SRT-10 (I did a forum search BTW) MK2_Viper SRT10 and SRT10 Coupe Discussions 22 06-05-2006 11:13 AM
Normal Temp 98viperGTS RT/10 and GTS Discussions 18 03-03-2005 08:02 AM
Temp Gauge Question BlackACR RT/10 and GTS Discussions 0 08-19-2001 09:28 PM
Normal engine temp at 80 degree weather Gerald Archive Management 0 06-10-2001 07:01 PM
Whats normal operating temp. if you just let the car sit and idle? NT FUSCUCLA1 Archive Management 0 10-30-2000 01:10 AM
