Old 03-29-2003, 08:15 PM   #1
Tom, F&L GoR
Site Sponsor
Tom, F&L GoR's Avatar
Default 40mm Rear Calipers
I went to Lime Rock, CT last Thursday with the latest iteration of modified Brembo rear calipers on my '94. The OEM size piston is 36mm, so 40mm is 23% more piston area, but that's just the math. The real benefit is that it balances the front and rear braking really well. Pretty neat to steam down the straight, brake hard without locking the fronts, and hear the engine speed increase when I let off the brakes. (Proportioning valve is disabled, no other prop valve installed.) It might now be a touch too much rear, since the car dances a bit over the road undulations, but I'll play with that by switching from R4 rear pads to Brakeman #3; from what I've read, B#3s are slightly lower coefficient of friction.
Normally I would see a post like this and think of it as bragging, but when the Porsche 996 driver asked me if I had ABS.... well, just had to share.
Old 03-29-2003, 08:38 PM   #2
Ron
Ron's Avatar
Default Re: 40mm Rear Calipers
Tom,
Clearly you've developed the lowest cost brake upgrade that actually works. I'll be following in your footsteps soon.
Makes you wonder why Dodge just didn't do it right in the first place since it's just a slightly different bit of machining...
Old 03-30-2003, 03:27 PM   #3
Nadine UK GTS
Nadine UK GTS's Avatar
Tom, great to read your post, can't wait to try your mod myself. My calipers are bored, pistons sleeved and the 40 mm seals came in from the US supplier Saturday. Thanks for all your help with this mod, including all the emails you kindly sent me re machining, sorting the seals etc. Way to go.
Nadine UK GTS is offline   Reply With Quote
Getting rid of 40mm Rear Calipers Tom, F&L GoR RT/10 and GTS Discussions 22 03-22-2005 07:57 AM
40mm rear brake calipers available Tom, F&L GoR Performance Modifications 9 12-14-2004 04:54 PM
40mm rear calipers - last ones Tom, F&L GoR RT/10 and GTS Discussions 10 09-29-2004 12:13 PM
Rear calipers with 40mm pistons Tom, F&L GoR Performance Modifications 0 07-25-2004 08:09 AM
40mm rear calipers available again Tom, F&L GoR RT/10 and GTS Discussions 0 07-24-2004 04:43 PM
