Old 05-21-2003, 10:44 AM   #1
TZL
Default Stoptech or Powerslot or other rotors?
Stoptech runs ~$800 with motul fluid and stainless line kit
Power slots are about $550 + stainless lines, so around the same price.
any other recommendations? feedback? which ones you like?
TZL is offline   Reply With Quote
Old 05-21-2003, 11:02 AM   #2
REDSLED
Default Re: Stoptech or Powerslot or other rotors?
Stop Tech 1pc or 2pc rotors? I run the Stop Tech 1pc slotted rotors for the track and they are only $145 each from Stop Tech. I've have good succcess with the Stop Techs and they have good customer service. There is a big price differnce between 1 & 2 pc rotors.
REDSLED is offline   Reply With Quote
Old 05-21-2003, 11:13 AM   #3
Stephen Yap
I don't think powerslots have 2 piece rotors like the Stoptech aerorotors. I don't know if prices you listed for the Stoptechs are for the 2 piece rotors but with an aluminum hat you get less weight and better heat expansion capabilities. Even if you don't track your car the 2 piece rotors look better. Also check the design and number of vanes as this helps in cooling and preserving the rotor. I don't know about the powerslots but the Stoptechs are TRACK TESTED as are the alcon rotors.
Now, if the goal isn't performance but looks, then check the Baer Eradispeeds instead of the powerslots.
Stephen Yap is offline   Reply With Quote
Old 05-21-2003, 11:22 AM   #4
Jerome Sparich
Short and to the point, Powerslots are junk. Leave them for the ricers.
Jerome Sparich is offline   Reply With Quote
Old 05-21-2003, 11:30 AM   #5
TZL
the price for stoptechs is for the "stage 2" brake upgrade, the picture looks like the 1 piece rotor
i basically do weekend driving, and probably track 3-4 times a year, is the added cost of 2 piece stoptech rotors worth it over 1 piece stop tech rotors?
thanks
ting
Old 05-21-2003, 11:43 AM   #6
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
I have two piece Stoptech.
Old 05-21-2003, 11:46 AM   #7
Stephen Yap
Hello Ting, the 1 piece rotors from Stoptech are only $160 each and the 2 piece are around $240 so I think that price is for the 2 piece so double check. Even if you track once a year, brakes are a weak point on that car. I'd think about pads too while you're at it.
Old 05-21-2003, 01:38 PM   #8
LETHAL GTS
Stoptechs & brakeman #3's w/SS lines. You wont regret it.
LETHAL GTS is offline   Reply With Quote
Old 05-21-2003, 02:51 PM   #9
TZL
i'm definately also doing pads
right now i'm just debating upgraded rotors/pads/lines vs full on big brake upgrade it....
btw, what in the bay are you located?
Old 05-21-2003, 06:19 PM   #10
Stephen Yap
San Ramon. I believe I've seen your silver ACR at Dublin Dodge. Good luck with the brakes. There is a lot of info on that subject if you do a search here or feel free to contact me if you have questions.
Old 05-22-2003, 02:02 PM   #11
Jay Lopez
N Texas VCA Member
I think EBC has a rotor out also now. Try the guys at greatbrakes.com .
Jay Lopez is offline   Reply With Quote
Old 05-22-2003, 03:13 PM   #12
TZL
Yeah it was a dublin dodge getting the ACR Koni's replaced under warranty about a month ago, i went there b/c that is where the previous owner had an open service ticket for the shocks.
i normally don't travel that far since i live/work on the pennisula
see you around,
Ting
Need New rotors for StopTech V10 ICBM Performance Modifications 5 07-21-2004 07:28 PM
stoptech rotors -help please varanus RT/10 and GTS Discussions 6 07-24-2003 01:00 PM
One set only: StopTech front rotors, StopTech/PowerSlot rear rotors! Bill/APEX Motorsports New Products, Supplier Specials, and Group Buys 2 05-29-2003 02:43 PM
I bought PowerSlot disc brake rotors at 94 RT/10 Black MAMBA Archive Management 0 12-18-2000 05:54 AM
STOPTECH OE Replacement Rotors now Available Jay Herbert New Products, Supplier Specials, and Group Buys 1 11-22-2000 10:20 AM
