Old 06-01-2003, 08:11 PM   #1
BlackACR
Default Dry shot of nitrous ( Who has been there??)
I would like to run a dry shot of Nitrous on my 96 GTS. A 100 shot would be perfect. I would like to run a very simple kit. Just a window switch and a bottle heater. How would I go about enriching the fuel for just the 100 shot dry?? Would the Vec 1 I have help any?? Any info is welcome.
BlackACR is offline   Reply With Quote
Old 06-01-2003, 08:48 PM   #2
1TONY1
1TONY1's Avatar
Default Re: Dry shot of nitrous ( Who has been there??)
If that is all you want buy the nos5180 kit and it takes care of the enrichment. Ditch the vec1 with n02.
Old 06-01-2003, 09:32 PM   #3
BlackACR
Thats a $1000 system. If I wanted do go that route. I would do NX wet kit and pick up a ton more power for less.
Old 06-01-2003, 09:35 PM   #4
varanus
But if you buy a vec one plus a base kit, aren't you at about the same cost almost?
varanus is offline   Reply With Quote
Old 06-01-2003, 10:46 PM   #5
Tom Welch
Tom Welch's Avatar
Hello,
One of our customers from Naples, Florida recently dynoed his 97 GTS at 563 RWHP with our exhaust system and basic "dry" nitrous system. This kit netted him @ 115 RWHP (thats 130+ at the flywheel). This system uses a controller to optimize fuel delivery to the engine during WOT/NOS application.
The NX system is not a dry system. It taps into your engines fuel system for nitrous supplementation. This is ok so long as a/f ratios are carefully monitored.
Feel free to contact me should you have any questions regarding our dry system.
Tom
Tom Welch is offline   Reply With Quote
Old 06-01-2003, 10:48 PM   #6
Jack B
Jack B's Avatar
NOS brand uses a modification that fools the PCM into thinking that the air temp is -20 degrees. It changes the resistance in the circuit that monitors the intake air temp and the coolant temp. The Vec 1 is nice for some applications, not N2O.
Old 06-01-2003, 11:31 PM   #7
Fast Freddy
i run a wet kit on my drag boat. that would be nos cheater system 4 dual carb applications. the system can spray anywhere from a 100 hp shot to a 250 hp shot. i run a dry nos kit on my 2001 honda cbr 929 motorcycle. i can adjust that one from 25hp-40hp shot. i have a nos dry kit 4 my 2001 camaro ss that i will be installing next year (75hp-125 hp). i have burned over 500 lbs of nytrus in my drag boat and never had a problem. gotta luv the spray. i will be getting nos dry kit 4 my viper. since i have no desire to drag race my viper, but instead road race in the future. my use 4 the nos will be used in 6th gear only. i have gone 180 mph in 5th gear when my car was bone stock. i want go 200 mph in 6th gear. so i am gonna spray the motor when i shift into 6th gear at 180 mph. btw i did this with my motorcycle. the bike would not pull 6th gear with the stock gearing and my heavy azz at 3000+ ft. elevation. i was hp limited to 161 mph in 5th gear. i geared the bike down and it would pull 6th gear but i was still only going 161 mph. so i re-geared it back 2 stock and sprayed the motor when i shifted into 6th gear at 161 mph and wadda ya know i hit 175 mph.
Fast Freddy is offline   Reply With Quote
Old 06-02-2003, 12:07 AM   #8
BigCarrot
Not so good on the motor to spray it in 6th gear, not good at all.
Old 06-02-2003, 07:14 AM   #9
1TONY1
1TONY1's Avatar
You said 100hp and dry shot. Thats a nos5180, its the only dry shot around that I know of. 100 hp give or take is all you will safely get dry (no propane or fuel) I have a BTR propane/nitrous for sell and also have a nos 5180 I might sell. Both are used in excellent condition and have only been on one car. Also the 5180 kit is the base kit for Tom's nos/propane. Does nos/propane work ? Ask anybody that was at the drag race at Bowling Green. The two fastest mod cars were BTR cars. p.s. I would also consider nos/propane a dry kit since both would be in a gaseous state in the intake. (Is that right Tom ? )
Old 06-02-2003, 07:25 AM   #10
BlackACR
My comment about the NX kit was about the wet system. That is the only way to get an NX kit is wet. If I was going to spend a $1000 it would be for more than 100HP and definitely wet. I was looking for just a little extra punch with out alot of hassle.
Old 06-02-2003, 07:50 AM   #11
1TONY1
1TONY1's Avatar
Whatever. JackB answered your first question on how to enrichen a dry kit.
Old 06-02-2003, 11:25 AM   #12
Snake Bitten
I am just about to install the NX Express system (wet, 150 shot)...Why should I not use the VEC-1 with it???
Snake Bitten is offline   Reply With Quote
Old 06-02-2003, 05:18 PM   #13
Fast Freddy
not sure what that vec-1 does but if it advances your timing that is not good. if anything u want to retard your timing when u spray. if u run a dry kit the stock timing should be ok as long as u run 100 octane unleaded race gas. also i would go 1 step colder on my spark plugs with a dry shot and narrow the gap on the spark plugs. personally if i were going to spray big doses from a wet kit i would do all of the above + retard my timing and have forged pistons 2.
Old 06-02-2003, 05:40 PM   #14
Jack B
Jack B's Avatar
For some reason when tuning a NOS engine, the VEC1 does not adjust immediately, there is a lag in the adjustment process. The whole key with NOS is consistency, the VEC1 hurts the tuning process. In addition, you cannot independently adjust a/f and timing. One last thing, if the injectors are maxed out the VEC1 does you no good which could be the case with a dry 100 shot. All that said, I would be the first to use the VEC1 on a NA engine with any sort of modification
Old 06-02-2003, 05:43 PM   #15
Snake Bitten
I wonder if I can relay the VEC1 out of the loop when the N20 is engaged???
300 Shot of nitrous safe on our cars??? INFURNA SRT10 and SRT10 Coupe Discussions 26 03-01-2006 06:51 AM
ok..nitrous creampuffs...what size shot ya using? prevnine11ownr RT/10 and GTS Discussions 1 06-11-2004 04:53 PM
RT/10 with 100 nitrous shot AlvaSpeed RT/10 and GTS Discussions 0 06-03-2004 04:55 PM
Dry Shot of Nitrous?? BlackACR RT/10 and GTS Discussions 3 02-16-2003 08:37 PM
200 shot Nitrous run 12.0 at 123 MPH, what't the deal? ACELLR8 Viper Racing/Dyno Results/Time Slips 24 11-19-2002 02:17 PM
