Old 06-23-2003, 02:44 PM   #1
BigCarrot
Default TNT Has a Blower!!!
This weekend at the Zone rendezvous, TNT had a car there with a blower on it. I haven't heard a word about it, but I spotted it in the garage. Apparently they are working to start production sometime soon. It's a top mount, similar to the Roe. What I thought was interesting was the fact that the throttle bodies are on the back of it, near the windshield! Here's some free advertising for you guys at TNT! It looks like the blower wars are getting a little more competition!
Old 06-23-2003, 02:56 PM   #2
b3rndtt0ast
Default Re: TNT Has a Blower!!!
hmmm, another roots blower? this could get interesting. would be cool for one that could put out over 8# of boost :-
D, or get one that can be innercooled :-D
b3rndtt0ast is offline   Reply With Quote
Old 06-23-2003, 03:03 PM   #3
Clint Sever
Uhh, sounds like last time - does it cost 7k installed ??
Clint Sever is offline   Reply With Quote
Old 06-23-2003, 03:18 PM   #4
RedGTS
If it's a roots blower, it would be the first one, not another one, as Sean's is a twin-screw. And yes, I know I'm being technical. Sorry.
RedGTS is offline   Reply With Quote
Old 06-23-2003, 03:23 PM   #5
BigCarrot
No, but show me one that does! My Roe is going to cost $7500, + the fuel pump booster and the crank keying kit, plus shipping. I figure it will be over $8k sitting on my garage floor. From what Nick had to say, the TNT package shouldn't be a TON more than the Roe. It's going to be an installed package, so the do-it-yourself guys like myself are out of luck. I like seeing the competition!
Old 06-23-2003, 03:48 PM   #6
ab
Site Supporter
ab's Avatar
What's the difference between the two?
Old 06-23-2003, 03:58 PM   #7
Larry Macedo
I believe the prototype Viper engine was designed to pull air in from the backside? Congrats to TNT for entering the war zone, should be interesting see their results.
Larry Macedo is offline   Reply With Quote
Old 06-23-2003, 04:01 PM   #8
BigCarrot
I really don't know yet. They had it covered with an aluminum plate. The obvious difference that I noticed was the throttle bodies on the back of the engine. No clue what the reason for this is, but I bet there is one. Maybe more room for an intercooler? Who knows.
Old 06-23-2003, 04:01 PM   #9
SapphireGTS
The basic difference between the twin screw and Roots blowers is the twin screw compresses the air inside the blower housing while the Roots type moves air to be compressed in the discharge manifold. The Roots are less expensive. Twin screws are less common and more difficult to manufacture. In short the twin screws take less power to drive, have lower discharge air temperatures at the same boost levels and typically are capable of higher boost levels than Roots blowers of the same general size. Also, the twin screw makes boost at very low rpm's just like a Roots and doesn't run out of breath nearly as fast in the higher rpm range.
Old 06-23-2003, 04:02 PM   #10
Clint Sever
Big - sorry, I should have made it more clear I was being sarcastic. This same kinda deal leaked out awhile back and was the running joke - before the Roe charger debuted.
Nevermind, lol...
Clint
Old 06-23-2003, 04:06 PM   #11
b3rndtt0ast
thanks for clearing that up, i havent done much research or anything on the roecharger, i just knew i sat ontop of da motor hehe.
-dan
Old 06-23-2003, 06:06 PM   #12
jkracer9
Was it on the saphire Viper? and if so that belongs to one of the TNT brothers. It has been installed for months, can't wait to see this one LOL.
jkracer9 is offline   Reply With Quote
Old 06-23-2003, 07:01 PM   #13
FE 065
If you look up inside your manifold with the throttle bodies off, you can see what look like core plugs at the back of each plenum. I guess you could reach around the back and feel them as well. They're at least 1.5" in diameter if I remember correctly. I had the thought some years ago of bolting small TBs to them for a primary/secondary kind of effect. Anything bolted to the back of the manifold would be a bear to get at though. "Installed package" means big $$$ for sure. Anyway, more good things are coming aren't they?
Old 06-23-2003, 07:03 PM   #14
joe117
I think the roots blower has two gear driven shafts, each with a cast aluminum rotor that has a cross section sort of like a peanut, you know, a lump on each end with a thin section in the center.
These two rotors turn against one another, the fat ends of each rotor fits into the thinner part of the other and vise versa, forcing the air around the inside of the housing.
The old diesel blowers, 4-71, 6-71, are roots type. Those were the ones you would see on top of a big V8 rail dragster.
joe117 is offline   Reply With Quote
Roe "blower only" 9.68 @ 143.5 mph 1TONY1 RT/10 and GTS Discussions 20 12-13-2006 12:27 PM
How to get 700+HP on ROE blower? jdoc7 RT/10 and GTS Discussions 10 10-23-2006 11:28 AM
Blower for my SRT........... Mach10 SRT10 and SRT10 Coupe Discussions 8 09-29-2005 05:46 PM
Anyone have a paxton blower go out on them? pullshard RT/10 and GTS Discussions 26 05-07-2004 11:08 PM
What blower is used? MadMaxx Archive Management 1 05-10-2001 08:17 AM
