Old 09-14-2003, 07:09 PM   #1
BACKNBLACK
Double Secret Probation
BACKNBLACK's Avatar
Default Door Hinges?
Are door hinges covered in warranty? I was having a problem when I was overseas with drivers door. Seemed it was rubbing on rubber when closing..If not, what is cost and is it easy to correct?
BACKNBLACK is offline   Reply With Quote
Old 09-14-2003, 08:23 PM   #2
JimDavis MT 97GTS 650R
Default Re: Door Hinges?
Should be covered by the basic 3/36 warranty. Not sure about extended plans. Sounds like a basic hinge adjustment, but be advised that your hinge is a single hinge unit, and is tricky to set up. Let the pros do it!
JimDavis MT 97GTS 650R is offline   Reply With Quote
Old 09-14-2003, 09:10 PM   #3
Jerry Dobson
Kansas City VCA Vice President
Jerry Dobson's Avatar
Yep, covered by 3/36 only, not extended.
Are you saying the stantion is rubbing the door seal? This is pretty common on Vipers. Where it rubs as you close the door.
Does it appear that the door is too far back or that the door sets too low?
If you want to do the repair yourself, I can go into more detail. To make the door perfect, plan on 1 to 4 hours.
Jerry Dobson
Jerry Dobson is offline   Reply With Quote
Old 09-14-2003, 09:26 PM   #4
RedSnakeGTS
it is ok for it to rub the weather stripping as you close it right? mine does it, but i have some wind noise in the upper corner of my driver's door. common?
RedSnakeGTS is offline   Reply With Quote
Old 09-15-2003, 02:20 AM   #5
varanus
Jerry-is this a fix without replacing the hinge? My door won't stay open and sags on my 97 GTS
varanus is offline   Reply With Quote
Old 09-15-2003, 02:30 AM   #6
Casey
Casey's Avatar
My drivers side broke in August. It's a $180- part, maybe $150 or so from Tator's.
I guess that part is specific to the Viper and no other models?
Extended warranty will not cover it from what I have learned.
Casey is offline   Reply With Quote
Lubing door hinges wastntim RT/10 and GTS Discussions 4 03-27-2007 09:02 AM
Viper door hinges MoparMan RT/10 and GTS Discussions 11 06-27-2006 12:12 PM
New door hinges at 5k miles? Kurt 97 GTS RT/10 and GTS Discussions 1 10-15-2002 08:49 AM
Door Hinges Supercharged Vipermad Archive Management 2 01-27-2001 01:04 PM
door hinges GTSnake Archive Management 3 10-28-2000 09:38 PM
