Old 10-22-2003, 12:27 AM   #1
GCHDEALER
Default Running Hotter??
I recently had my radiatior replaced under warranty because a metal band on it came apart, got into the fan, and poked a hole in it. Now that the dealership put a new radiatior in it, the temp climbs up to the next hash mark between the 190 and 250. Before I had this warranty work done It never ran above the 3 little center hash marks at 190. It will still cycle back down to the 190's but runs to high to soot me around town. The coolant level is full any suggestions?
Chad
GCHDEALER is offline   Reply With Quote
Old 10-22-2003, 01:00 AM   #2
Craig 201 MPH
Default Re: Running Hotter??
waterpump impellor is my guess.
Craig 201 MPH is offline   Reply With Quote
Old 10-22-2003, 01:31 AM   #3
Clint Sever
Is this your 2001? If so, I'm with Craig - the impellers on the waterpumps in 01 were plastic and they easily break/slip/fail. Get that impeller replaced with a metal unit and you should be fine.
Clint Sever is offline   Reply With Quote
Old 10-22-2003, 04:21 AM   #4
ACR Joe
ACR Joe's Avatar
Was the system bleed properly?
ACR Joe is offline   Reply With Quote
Old 10-22-2003, 06:17 AM   #5
SylvanSRT
SylvanSRT's Avatar
water pump design and impellers are the same on all vipers and years.
Old 10-22-2003, 06:31 AM   #6
Miles B
Sylvan,
I believe there was a bad batch though that went on cars around 2001?
Miles B is offline   Reply With Quote
Old 10-22-2003, 06:41 AM   #7
SylvanSRT
SylvanSRT's Avatar
u are correct, i had one(two actually), still the design on all year waterpumps are the same). the prob was a plastic impeller shaft, w/ a metal "thimble" pressed on end to drive it. the shaft would then spin inside the end of the thimble and not turn the waterpump, and not circulate the coolant.
Old 10-22-2003, 08:12 AM   #8
dwhitt
dwhitt's Avatar
possibly a "burp" is needed on the coolant
dwhitt is offline   Reply With Quote
Old 10-22-2003, 08:17 AM   #9
SapphireGTS
Mine was a water pump. Put a 180 T-stat in it too.
Hotter air hotter engine? joe117 Performance Modifications 5 06-01-2005 05:08 PM
Car running "rich." Would colder or hotter plugs make a difference? J DAWG RT/10 and GTS Discussions 0 05-17-2004 03:47 PM
One side of car hotter than the other? ntmatter RT/10 and GTS Discussions 2 09-02-2002 12:37 PM
Just gets hotter varanus RT/10 and GTS Discussions 16 07-31-2002 12:03 AM
Running Hotter Than Normal? Matt M, PA RT/10 and GTS Discussions 0 09-08-2001 06:21 PM
