Old 11-07-2003, 07:54 PM   #1
Rock Chalk
Default Suspension
Where can I find a Delrin Bushing Kit 94 RT/10? And what are a good set of shocks and springs. I dont need an elaborate setup. Unless of course someone would like to get me a set for Christmas.
Rock Chalk is offline   Reply With Quote
Old 11-07-2003, 07:59 PM   #2
BadVenm
Default Re: Suspension
Jon B at Partsrack.com
BadVenm is offline   Reply With Quote
Old 11-07-2003, 08:47 PM   #3
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
www.roeracing.com
I have a brand new set that I haven't even put on. Might sell if you're interested.
Old 11-08-2003, 08:45 AM   #4
Hoosier Daddy
Hoosier Daddy's Avatar
I had Archer racing in Minnesota install there bushings into the 8 upper and lower A Arms. Wasn't cheap! I sent them to him last winter to install in the arms. These are greaseable ones. They worked real well. Every track that I was timed at I cut off more than a second at minimum. During the rainy One Lap of America this year we did have to stop and get a grease gun to quiet down the squeaking down. Did not feel a significant change in road vibration going to these from the rubber stock ones unlike I was told to expect..
Hoosier Daddy is offline   Reply With Quote
Old 11-08-2003, 03:48 PM   #5
V10 MOJO
any undesirable aspects of a delrin set upgrade?
V10 MOJO is offline   Reply With Quote
Old 11-10-2003, 01:05 AM   #6
DMC94
I have a full front/rear Delrin set for a 94 from Northwind that I didn't install. Let me know if you're interested.
DMC94 is offline   Reply With Quote
Old 11-10-2003, 10:44 AM   #7
K Adelberg
If you are going to go through the costly expense of a bushing change, why bother with Delrin? The best thing is a spherical bearing set up! While aligning the car you will still have trouble acquiring an aggressive track alignment. With Delrin the suspension will still experience some binding. My $0.02, not really worth it!
If you want suspension for a low price, get the Koni ACR set up off a 99 ACR Viper.
K Adelberg is offline   Reply With Quote
Old 11-10-2003, 11:53 AM   #8
Bugeater
Adelberg,
Does the 99 ACR setup contain different bushings over GTS?
If they dont, I'm not sure I understand your last sentence in your post, when the discussion has been on the bushings...
Bugeater is offline   Reply With Quote
Old 11-10-2003, 05:08 PM   #9
WCKDVPR
Who sells the spherical bearing set up?
Thanks,
WCKDVPR is offline   Reply With Quote
Old 11-10-2003, 06:55 PM   #10
FrankBarba
I purchased the bushing set from NorthWind for my 95, had nothing but problems. My upper A-Arms were colapsing. Had lots of aligment issues and very bad tire wear. I informed them of this sent pictures and various emails back & forth. Nothing was ever resolved. So i contacted the Dr. Woodhouse, he helped take care of my problem.
FrankBarba is offline   Reply With Quote
Old 11-10-2003, 07:05 PM   #11
Chuck 98 RT/10
Thanks,
I believe Erik Messley at EMI Racing in Huntington Beach, CA. (714) 899-3669 emiracing@mindspring.com
Of Paul Mumford fame.
Old 11-10-2003, 08:20 PM   #12
KepRght
KepRght's Avatar
What did he do to fix your problem?
KepRght is offline   Reply With Quote
Old 11-14-2003, 10:21 AM   #13
K Adelberg
The 99 had the same rubber bushings as all the years. Delrin is a, pardon the expression, mickey mouse way to relieve the binding of the control arm at its pivot point. Delrin may relieve some, but still will bind when you try to adjust caster and I think also toe. In addition, the control arm is really not able to move freely. Best spherical bearing package is done by Erik Messely at EMI. Yes, Erik was the "Chassis Engineer" for Paul Mumford's thrashing on the World Challenge field.
I mentioned 99 ACR Vipers as a cheap suspension upgrade. The 99 ACR had the best Koni shock and spring set up. The external reservoir on the newer set up was not as good.
Old 11-14-2003, 11:10 AM   #14
Frank Parise
Frank Parise's Avatar
There have been significant improvements in the Delrin bushins marketed to Viper owners. The original set I purchased in 1997 were not greasable and did not have steel sleeves inside. They eventually wore out and would not hold an alignment after 2 race seasons.
Greasable Delrin bushings with steel sleeves inside are a substantial improvement over the factory rubber bushings. They free up the movement of your control arms and are worth the investment if you are serious about reducing lap times.
If you have an unlimited bidget and want to spend 3 or 4 times as much on materials and installation, spherical bushings such as those that come on the Comp Coupe are superior because they have less "stiction" than the Delrin. They may wear out quicker than Delrin.
Kenny, I've owned both a 99 and a 01 ACR. I find the newer Dynamic shocks with external reservoir and the stiffer spring set up to be far superior from a performance standpoint and much easier to adjust, with a wider range of adjustments, than the older Koni/soft spring set up. The ACR has the same bushings that come in a GTS.
Frank Parise is offline   Reply With Quote
Old 11-15-2003, 01:10 AM   #15
Bugeater
whats the difference between the 99 and 00 Koni setup? I assume nothing....
btw, the "soft spring setup" is 400bs F, 750 Rear, correct?
KW suspension same as [******]'s? 2 VENOMOUS SRT10 and SRT10 Coupe Discussions 1 09-12-2006 11:47 PM
suspension set up and changes. Catwood RT/10 and GTS Discussions 9 11-11-2005 07:35 PM
Suspension AllBlack SRT10 and SRT10 Coupe Discussions 15 05-03-2005 01:06 AM
GTS vs. ACR Suspension REDSLED RT/10 and GTS Discussions 17 12-13-2002 10:28 AM
