Are there any Viper owners in the Dallas area that has Random Tech Mid/High Flow CATS that HAS PASSED the emission insection?
Are there any Viper friendly test locations? I want to install Random Tech Mid/High Flow CATS on my 96 RT/10 but I wanted to ensure that it will pass the emission inspection. |
I posted last week that my 00 GTS failed with the RT M/S high-flow cat's.I think the year of the car matter's because when this happened to me I called Mike in Guelph that's a supplier on this board. He said 4 other Viper's have passed with those cat's in Ontario; none were my year of Viper.
I had the High flows on my 94 and it passed with flying colors as a matter of fact they said it was one of the cleanest Gen 1's they had ever tested at the dealership. You may want to check the cats and make sure they are not damaged, you should pass unless you have really agressive mufflers as well.
I believe they are warranted by RT to PASS. Read the literature and warranty info but can't recall the exact wording.
i am from dallas, and mine passed. i went to Huffines Dodge in lewisville, and passed.
Using Random Tech high flow ceramic type cats on 97 GTS, I passed echeck in Ohio with very low numbers, much lower than the limits.
HC tested 2.6PPM limit 220PPM. CO tested at 0,0 limit 1.2 You should have no problem passing the test whether Viper friendly or not. Warranty to pass is for 2 years. I do not know what test limits are in Dallas but the above numbers may help. Be sure to warm it up good before testing. |
I hope I will pass when the time comes!
I'll find out in about two weeks. I have to have mine done. I'll have it done by the McKinney Dodge dealership. I'll let ya know.
Contact Keith Laxson or Roger Medina if you have emission difficulties at All Pro Automotive in Carrollton.
#10 | |
Thanks guys... I appreciate your responses.
I had the Randon Tech installed and I am very pleased with the cooler side sills. I will have the BigSnake inspected in January. I think that I am going to Huffines Dodge in Lewisville... Thanks again.. |
Shelby 3.If you are correct then you don't need cats to pass.Just a couple of snake boxes plugged in to fool your ECM. Bruce
#13 | |
Be sure to post your results after the test!!! Thanks |
| BEWARE of Those Random Tech Cats | Dimitrios | SRT10 and SRT10 Coupe Discussions | 53 | 08-30-2007 02:17 AM |
| Random tech cats broken.... | SRTRICKY | SRT10 and SRT10 Coupe Discussions | 51 | 04-27-2007 06:04 AM |
| Need the low-down on ROE vs Random Tech Hi-Flow Cats | pocketAA | RT/10 and GTS Discussions | 8 | 04-11-2007 09:48 AM |
| Random Tech Cats | WildWing | SRT10 and SRT10 Coupe Discussions | 2 | 05-23-2006 09:06 AM |
| Help! Re: Random Tech Cats need pic of before and after.... | TAXIMAN1 | RT/10 and GTS Discussions | 5 | 07-08-2005 09:13 PM |
