Old 12-15-2003, 03:18 PM   #1
ab
ab's Avatar
Default Autometer boost gauge..other gauge related questions
How accurate it the Autometer mechanical boost gauge? Anyone test it out?
Also the Air/fuel meter they have with the blinking lights, is that accurate too or would you go with a egt gauge instead with measuring the temp to tell you if you run lean?
Old 12-15-2003, 03:38 PM   #2
SapphireGTS
Default Re: Autometer boost gauge..other gauge related questions
Adam
I have the boost gauge from autometer. Seems to work pretty well. I did it for looks, I have to admit. But there is functionality there. I am having Scott at Elite do a wide band a/f meter to know where I am. Nothing worse than running too lean.
Are you going to stop pussyfooting around and blow that thing!!!!?
Need help finding the steering column pod for an autometer 2 1/16 gauge. ab RT/10 and GTS Discussions 4 08-13-2006 10:32 PM
Gauge pod again ... (Need Autometer part number) Schulmann RT/10 and GTS Discussions 7 01-15-2005 10:03 AM
anyone use the Autometer electric fuel pressure gauge? ab RT/10 and GTS Discussions 4 11-04-2004 08:20 AM
Boost Gauge SapphireGTS Performance Modifications 29 10-13-2003 11:35 PM
Autometer Oiltemp gauge installation jp RT/10 and GTS Discussions 2 02-15-2003 09:53 PM
