Old 02-07-2004, 08:35 AM   #1
FLX109
FLX109's Avatar
Default Side exhaust pipe covers with rear exhaust pipes ???
Does anyone have a rear exhaust GTS viper with side exhaust covers, I have heard their is someone who is in the club who has their rear exhaust shortened and tucted and also shows side exhaust covers, I like the side exhaust look but the rear sound, any pictures around or info?
FLX109
FLX109 is offline   Reply With Quote
Old 02-07-2004, 09:49 AM   #2
PBJ
Default Re: Side exhaust pipe covers with rear exhaust pipes ???
I did a set up for a customer on a GTS ... I used side exhaust sills and welded on a flange at the side port with a aluminum cover to block off when he is not at the track. He can use side exhaust or cap it off and it will be rear exit for normal every day driving. I tested it on a dyno and the car made 8 rwhp and 11 rwtq more with the caps off...I never knew how restrictive the rear muffler really was. It is odd to see with both, but the customer wanted a quiet car for daily driving and a little edge at the track. I want side exhaust for my car, but I don't want my rear fascia left open. Autoform sells a filler panel, but I am afraid you would be able to see a seam after it was blended in...it is tough to patch something that size. I am not sure if a RT 10 rear fascia will fit on the back of a GTS...if it would I would change to side exhaust in a second. If you want, I will try to get a pic from Tom and get it to you. Hope that helps.
Later,
Joe
PBJ is offline   Reply With Quote
Old 02-07-2004, 11:00 AM   #3
FLX109
FLX109's Avatar
If you can get a picture it would be appreciated
FLX109
Old 02-07-2004, 12:16 PM   #4
BigCarrot
There is a guy in Dallas that has both. Looks dumb in my opinion.
Old 02-07-2004, 12:39 PM   #5
GTSnake
GTSnake's Avatar
Yes, pictures please!
I was thinking the exact same thing. Although I would want the rear tips to be pointed down and cover up the facia opening.
Old 02-08-2004, 09:35 AM   #6
FLX109
FLX109's Avatar
Does anyone have this setup?
Old 02-08-2004, 10:09 AM   #7
PBJ
Bill,
you have mail.
Joe
Old 02-08-2004, 06:25 PM   #8
FLX109
FLX109's Avatar
Pictures from Joe
FLX
Old 02-08-2004, 07:41 PM   #9
Newport Viper
Newport Viper's Avatar
black out the covers, then it will look fine.
Old 02-08-2004, 11:30 PM   #10
ROCKET62
IL VCA Member
ROCKET62's Avatar
I've often wondered if the area in the side sills would be big enough to accomodate one of the electric exhaust cut-outs? That way you could have the quiet ride and wide open side pipes at the flick of a switch at the same time.
Old 02-09-2004, 07:50 PM   #11
FLX109
FLX109's Avatar
Here's a concept picture I found with both the sidepipes and rear exhaust
don't look bad
FLX109
Old 02-09-2004, 07:52 PM   #12
Newport Viper
Like the way you think Rocket62!!!!!!
The ricers would soil there seat, when you pull up to them!
Old 02-09-2004, 11:30 PM   #13
WilBriK
"Here's a concept picture I found with both the sidepipes and rear exhaust
don't look bad"
Forget not looking bad. It looks BADASS! Once I get my car, I'm definitely getting the conversion done. Thanks for the pic. That absolutely eliminated any doubt I had about the conversion.
WilBriK is offline   Reply With Quote
Old 02-10-2004, 05:31 AM   #14
FLX109
FLX109's Avatar
Here's another one
Old 02-10-2004, 07:07 AM   #15
GTSnake
GTSnake's Avatar
Rocket,
Where did you find this set up? What size are the openings?
Side pipe covers/borla exhaust what's it worth? Mopar Steve RT/10 and GTS Discussions 4 09-06-2005 07:40 AM
Side pipe exhaust and headers??? Gottaviper Performance Modifications 9 06-09-2004 12:14 PM
Side Pipes or Rear Exhaust?? Decisions, Descisions... Yellow Fever RT/10 and GTS Discussions 16 09-22-2003 11:42 PM
Side Pipes & Rear Exhaust? WilBriK RT/10 and GTS Discussions 3 07-29-2003 11:23 AM
I need exhaust tips for my side pipes Mopar Steve Archive Management 1 12-23-2000 08:16 PM
