Old 06-11-2004, 02:48 AM   #1
DodgeViper01
Default HELP: Car Making Weird Noise; Like Wheel Is Rubbing Against The Wheel Well
Hey guys:
I am having another dilemma. For a while my car has been making this weird noise, like the wheel is rubbing against the wheel well. This only happens when you turn the steering wheel but when you turn it almost all the way or all the way the noise gets pretty loud. Anyone ever experience this? Is this normal? It is quite annoying to tell you the truth. Any help would be greatly appreciated.
Thanking everyone in advance.
Keith
Old 06-11-2004, 06:34 AM   #2
CROM
CROM's Avatar
Default Re: HELP: Car Making Weird Noise; Like Wheel Is Rubbing Against The Wheel Well
I noticed that when I turn the steering wheel the whole way in either direction I get a loud noise. It's not wheel rub, but sounds like the powersteering pump is working extra hard. Solution, I just dont crank the steering wheel the whole way in either direction. The only time I ever have to do this is when I am pulling out of my garage.
Old 06-11-2004, 07:31 AM   #3
FE 065
I haven't had that problem, but I have refrained from moving the car around with the hood raised up to the first position from fully closed.
The bottom corner of the hood under the side Viper logo comes VERY close to the front tires with the hood in that position!
Old 06-11-2004, 07:58 AM   #4
motor602
motor602's Avatar
keith does it happen on both sides, and have you noticed any abnormal tire wear??
motor602 is online now   Reply With Quote
Old 06-11-2004, 08:08 AM   #5
Bill B
FL VCA Member
Bill B's Avatar
Are you sure that it isn't hitting? If you have lost some of the screws it just may come in contact.
Bill B is offline   Reply With Quote
Old 06-11-2004, 11:31 AM   #6
DodgeViper01
Both sides. It is weird. I am going to probably take it to a dealer to check it out. The sound sounds horrible
Old 06-11-2004, 02:56 PM   #7
onerareviper
Read all my posts....
http://vca2.viperclub.org/forums/sho...rue#Post258393
Old 06-11-2004, 04:58 PM   #8
2BADD 4U
Call Chuck Tator ...914-763-3136
2BADD 4U is offline   Reply With Quote
Old 06-13-2004, 12:12 AM   #9
DodgeViper01
Was already doing that. Funny you mentioned that. I spoke to Chuck today and we came up with a few possibilities. I am going to have Buhler look at it.
19 inch. wheel rear wheel lip depth. need your inputs please.. vipeuup RT/10 and GTS Discussions 1 09-13-2005 02:16 AM
Help my Viper is making weird sounds under the car! supratime RT/10 and GTS Discussions 17 01-26-2005 10:53 AM
Hardtop and Rubbing In The Wheel Well - At Buhler Once Again! DodgeViper01 RT/10 and GTS Discussions 2 10-26-2004 05:28 PM
Rear Wheel Rubbing safireviper RT/10 and GTS Discussions 2 07-14-2002 03:07 PM
wheel hop, banging noise, at my whits end FastMatt RT/10 and GTS Discussions 14 06-23-2002 06:17 AM
