VCAWHERE importuserid=Germany
Hi,
the radiator fan of my ī96 RT/10 is not starting when engine is running hot. The fan works when directly connected to the battery. It seems, that I have to check and replace the fan fuse. This fuse is located in the fuse box in engine compartment, but I canīt find this fuse box My service manual does not describe the location of this box; I tried to find this box near the battery charge location (drivers site), but there is nothing ? Cheers boatman |
there is a fuse box in the car under the dash on passanger side front bolster.... |
it's right under the hood on the left above the PCM cover...jus above the drivers feet....there is 2 different covers there...pull the top off and you'll see the fuses!!...Len
Yes right, thanks Adam, I found that fuse box inside the car, but the service manual describes that the fuse for the radiator fan is in another fuse box under the hood, inside engine compartment.
Boatman,
Here's where the fuse panel is on my 97. The fuse for the fan is the red 50 amp fuse on the radiator side of the panel. |
Thanks txlen !
VPRVENM97: Thanks for the picture Now I found that fuse box !! |
| red fluid in engine compartment | Muzz B Yellow | SRT10 and SRT10 Coupe Discussions | 6 | 08-11-2005 03:20 PM |
| Help on cleaning engine compartment | SHADOW | RT/10 and GTS Discussions | 8 | 08-01-2005 03:22 AM |
| Best way to clean the engine compartment? | Abq Bill | RT/10 and GTS Discussions | 13 | 04-17-2005 12:21 AM |
| engine compartment fires? | onerareviper | RT/10 and GTS Discussions | 6 | 03-16-2002 07:45 AM |
| BRIGHTEN UP YOUR ENGINE COMPARTMENT WHILE GAINING UP TO 10 RWHP!!! | Tom Welch | Archive Management | 3 | 01-22-2001 09:14 PM |
