Old 07-23-2004, 06:22 PM   #1
AG98RT10
Default Clutch issue...
Found a small puddle under my tranny and pretty sure I have a fluid leak in the clutch hydraulic system. Won't engage gears after starting until I top off the clutch reservoir and pump it up. Then works normally until it sits for awhile and clutch appears to take a small dump of Motul fluid and won't work until topped off again. Vipertech says probably the slave cylinder inside the clutch that's cut loose. Anyone had this happen??? I'm thinking I probably will have to pay someone to drop the clutch/tranny connection point anyway so might as well put a new clutch in while I'm at it? RT has 19K.
Any insight appreciated.
AG98RT10 is offline   Reply With Quote
Old 07-23-2004, 06:52 PM   #2
Ulysses
Default Re: Clutch issue...
it's not unheard of. At 19K you've probaly used it enough to where it would warrant a clutch disk and pressure plate change if the tranny is coming out anyway, it couldn't hurt (except in the wallet) and you won't have to worry about soon down the road. Might be a good time to change out the flywheel to a light weight too if you have been thinking about it. Throw out bearing and slave cylinder are one unit.
Ulysses is online now   Reply With Quote
Need Advice/Help - Clutch Issue viprvenm RT/10 and GTS Discussions 3 03-09-2007 06:08 PM
Clutch Questions, drove friends viper, clutch much easier to engage..... Dieselino RT/10 and GTS Discussions 2 08-13-2006 01:44 PM
Clutch issue John Johns RT/10 and GTS Discussions 2 08-14-2005 09:19 PM
Clutch Issue Question DViper SRT10 and SRT10 Coupe Discussions 10 03-17-2005 02:30 AM
A/C Clutch Wiring Issue - Guru with Wiring Diagrams Needed Dave Adkins RT/10 and GTS Discussions 2 08-23-2004 04:43 PM
